Esp8266+Ardunio mega+ camera OV7670
Hello
I want to send live video to esp8266 which acts as other receiver by using esp8266 module.And
2. I want to transfer the live video from Arduino to the computer with the help of the port and watch the live video.how can I do that?
i found software that reads camera data from port.
An ESP32-CAM module can do all that for you with no extra programming.
I plan to use 4 cameras and take a single image.but Is it possible to connect 4 esp32s together and provide a single image?
I suppose you could stitch them together.
What's the purpose instead of using a higher resolution image?
Are these 4 cameras looking at 4 different things or the same thing?
Explain your larger purpose and you'll probably find that there's already some software solution.
cameras looking at different points and they will be attached to a model rocket. Therefore, it is necessary to obtain a single image and watch the image on the computer.
You're likely to have connectivity issues unless you add antennas to the modules and have a powerful router.
I'd look for a security camera program that lets you multiplex 4 IP cameras.
thank you
