ESP8266 AT+CIPSTART="SSL","www.google.com.au",443 ERROR CLOSED
Does anyone know why this command won't work with "ESP8266 NONOS SDK V1.5.4" or if there is a version of this firmware for which this command will work.
What are the arguments for the CIPSTART command? I thought, though I certainly could be wrong, that the first one was a URL. "SSL" doesn't look like a URL.
PaulS:
What are the arguments for the CIPSTART command? I thought, though I certainly could be wrong, that the first one was a URL. “SSL” doesn’t look like a URL.
AT+CIPSTART=,,[,]
AT+CIPSTART=,,,[,]
• : ID of network connection (0~4), used for multiple connections.
• : string parameter indicating the connection type: “TCP”, “UDP” or “SSL”.
• : string parameter indicating the remote IP address.
• : the remote port number.
• []: detection time interval when TCP is kept alive; this function is disabled by
default.
‣ 0: disable TCP keep-alive.
‣ 1 ~ 7200: detection time interval; unit: second (s).
Examples
AT+CIPSTART=“TCP”,“iot.espressif.cn”,8000
AT+CIPSTART=“TCP”,“192.168.101.110”,1000
According to the manual provided.
