Esp8266 AT Commands
Im trying to send this data with a GET Request to a server but it hangs at the end:
#include "SoftwareSerial.h"
#include "DHT.h"
#define DHTPIN A1     // what pin we're connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302)
DHT dht(DHTPIN, DHTTYPE);
String ssid ="myssid";
String password="mypwd";
String server = "santiapps.com"; // www.example.com
String uri = "/emoncms/input/post";
#define EMON_APIKEY F("mykey")
byte dat [5];
String temp ,hum;
String data;
char dataString[20];
char tempString[20];
char humString[20];
SoftwareSerial esp(6, 7);// RX, TX
  esp.begin(9600);
  Serial.println("setup");
  reset();
  connectWifi();
void reset() {
  Serial.println("reset");
  esp.println("AT+RST");
  if(esp.find("OK") ) Serial.println("Module Reset");
void connectWifi() {
  Serial.println("connect to wifi");
  String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
  esp.println(cmd);
  delay(400);
  while (esp.available()){
     String inData = esp.readStringUntil('\n');
     Serial.println("Got reponse from ESP8266: " + inData);
  if(esp.find("OK")) {
    Serial.println("Connected!");
    connectWifi();
    Serial.println("Cannot connect to wifi"); }
void start_test () {
  //For DHT22 Grove Pro
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  dtostrf(t, 4, 2, tempString);  //convert flat to char
  dtostrf(h, 4, 2, humString);  //convert flat to char
  strcpy(dataString,tempString);
  strcat(dataString,humString);
  Serial.println(dataString);
void loop(){
  Serial.println("loop");
  start_test();
  httppost();
  delay(100000);//100k ms = 100s or ~ 1.8m
void httppost () {
  esp.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
  if( esp.find("OK")) {
    Serial.println("TCP connection ready");
//  //CODE USED TO BUILD COMPLETE STRING
/* A GET has no separate header and data block. Very simply:
 * GET /emoncms/input/post.json?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&node=xx&csv=xx,xx,xx,xx\r\n\r\n
  String nodeData1="/emoncms/input/post.json?node=fortnite&json={\"t\":";
  String nodeData2=nodeData1 + tempString;
  String nodeData3=nodeData2 + ",\"h\":";
  String nodeData4=nodeData3 + humString;
  String nodeData5=nodeData4 + "}";
  String apiKeyString="&apikey=";
  apiKeyString.concat(EMON_APIKEY); //JOIN PARAMETER LITERAL STRING => String Object
  String finalData=nodeData5+apiKeyString; //COMBINE BOTH PREVIOUS STRING OBJECTS
  Serial.println(finalData);
  String getRequest="GET " + finalData + " HTTP/1.0\r\n"+"Host: " + server + "\r\n" + "Connection: keep-alive\r\n\r\n";
  String requestLength = String(getRequest.length());
  Serial.println("getRequest");
  Serial.println(getRequest);
  String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
  esp.print(sendCmd);
  esp.println(requestLength);
  if(esp.find(">")) {
    Serial.println("Sending..");
    esp.print(getRequest);
    if(esp.find("SEND OK")) {
      Serial.println("Packet sent");
      while (esp.available()) {
        String tmpResp = esp.readString();
        Serial.println(tmpResp);
      // close the connection
      esp.println("AT+CIPCLOSE");
I get this in the SM and no post in the emoncms server:
setup
reset
connect to wifi
Got reponse from ESP8266: AT+CWJAP="myssid","mypwd"
Got reponse from ESP8266: WIFI DISCONNEC
connect to wifi
Got reponse from ESP8266: busy p...
Connected!
loop
29.5051.60
/emoncms/input/post.json?node=fortnite&json={"t":29.50,"h":51.60}&apikey=mykey
getRequest
 HTTP/1.0
Host: santiapps.com
Sending..
Packet sent
+IPD,311:HTTP/1.1 400 Bad Request
Server: nginx
Date: Mon, 08 Oct 2018 02:00:11 GMT
C
