ESP8266 - Authentication and Data Encryption WPA-PSK, TKIP settings
Hello,
I’m trying to make a little standalone AP Web Server with WeMos D1 mini, but I can’t figure out how to set the AP parameters to work with my HP iPAQ hx2410.
I need to configure my WeMos D1 mini AP with these specific parameters, to be able to connect:
Channel: 1
Authentication: WPA-PSK
Data Encryption: TKIP
Sketch what I’m using:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
const char* ssid = "MyAP";
const char* password = "12345678";
ESP8266WebServer server(80);
void handleRoot()
  server.send(200, "text/plain", "Hello from esp8266!");
void setup(void)
  Serial.println("");
  WiFi.mode(WIFI_AP);
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("IP Address: ");
  Serial.println(myIP);
  server.on("/", handleRoot);
  server.begin();
  Serial.println("HTTP server started");
void loop(void)
  server.handleClient();
I know that, if I put “1” into the last parameter it will force to use Channel 1, but I can’t connect to it still:
WiFi.softAP(ssid, password, 1);
But, if I disable the encryption by removing the password (AP to be Open), it’s connects immediately.
I hope someone can help me out with my issue!
Thank you!
Regards
Can other, non-ancient devices connect?
ElCaron:
Yes, it can, but the HP iPAQ hx2410 can connect to my home AP with those specific settings.
So, I wonder, is there any possibility to achieve that with my “ancient device”?
Could be a WPA vs WPA2 issue? Or an encryption issue? I don't see you setting either explicitly and apparently you want legacy standards for that.
ElCaron:
Could be a WPA vs WPA2 issue? Or an encryption issue? I don’t see you setting either explicitly and apparently you want legacy standards for that.
Yes, I think there is an encryption compatibility issue, but I can’t figure out for the “ESP8266 Arduino” is there any function to be able to set the encryption method or settings like that (I just found the Channel forcing parameter).
I can’t find any normal documentation for it, and I already posted it 12 days ago on the official GitHub page the same question, but no one is responding to it.
Regards
I tried a quick google for the last post, but did't find anything either. Well, you know what to look for. Report if you find anything :slight_smile:
ElCaron:
I tried a quick google for the last post, but did’t find anything either. Well, you know what to look for. Report if you find anything :slight_smile:
Yeah, I will! Kappa :wink:
