ESP8266 BAUD Rate
Hello everybody,
I have an ESP8266 WIFI module, i change the BAUD rate to 9600 using AT commands and it gives ok but it strangely gets back to 115200 whenever i turn the module off!
if your esp8266 module firmware is 1.4, then you can permanently set the baud rate using AT+UART_DEF=9600,8,1,0,0
if your firmware is not 1.4, I recommend updating it to 1.4.
