ESP8266 BME280 enviando datos a mysql Excepcion (28)
Hola
Quiero enviar los datos de BME280 con un nodemcu 0.9 a mysql pero me da un error y no encuentro el fallo ni la web donde baje el codigo. El codigo es el siguiente:
/* Sensor Interface v 1.0
Made by David S. - At-M - in 2018
Line 19 - 34 is changeable
// Generally needed
#include <MySQL_Connection.h> // MySQL Connector
#include <MySQL_Cursor.h> // MySQL Connector
#include <ESP8266WiFi.h> // Wifi Connector
//BME/BMP280 specific
#include <Wire.h> // Wire Library
#include <Adafruit_Sensor.h> // Adafruit Sensor Library
#include <BME280I2C.h> // include BME280 Sensor (0x76)
BME280I2C bme; // Default : forced mode, standby time = 1000 ms Oversampling = pressure ×1, temperature ×1, humidity ×1, filter off,
// Changeable Stuff
// Sensorspecific
int sensorname = 4; // Sensor no. to differentiate results
long interval = 30000; // Interval at which to check data in ms (15min = 900000ms, 30sek = 30000ms) DONT CHECK FASTER THAN 2000ms! The BME/BMP will heat up or behave strangely!
// WiFi
char ssid = "TP-Link_F0D0"; // Your Networkname
char pass = "09565616"; // Your Networkpassword
IPAddress ip(192, 168, 0, 108); // Ip of this device in your network
IPAddress gateway(192, 168, 0, 1); // Gateway this device looks for (The same IP as your router should work in most cases)
IPAddress subnet(255, 255, 255, 0); // Subnet this device looks for (255.255.255.0 should work in most cases)
// MySQL
IPAddress server_addr(192, 168, 0, 104); // IP of your MySQL Server
char user = "root"; // Your MySQL user
char password = "mipassword"; // Your MySQL password
char INSERT_SQL = "INSERT INTO autohome.sensordata (sensorid, sensor, humedad, presion, reading_time, temperatura) VALUES (NULL, 'Salita', '%s', '%s', CURRENT_TIMESTAMP, '%s')";
// Do not change stuff below this line if you're not knowing what you're doing!
int wificonnect = 0; // checks the wificonnection 1 = connected
int connectloop = 0; // counts the number of tries
WiFiServer server(80);
WiFiClient client;
MySQL_Connection conn((Client *)&client);
char query[128]; // max query length
long previousMillis = 0; // Will store the last time when sensors were read
int dbconn = 0;
float var_temp(NAN), var_hum(NAN), var_pres(NAN);
// Functionprototypes
void checksensor();
void wififunction();
void dbupload(char*, char*, char*);
// Runs once
Wire.begin();
//WiFi.persistent(false); // to fix unnecessary writing to flash and "random" connections to wifi, does not seem to work properly
Serial.print("Sensor: ");
Serial.println(sensorname);
Serial.print(F("IP : "));
Serial.println(ip);
Serial.println("");
Serial.println("AT+CWMODE_CUR=1"); // Sets ESP8266 as Client (avoids broadcasting a network)
Serial.println("");
// Repeating code
int i = 0;
// run following code after each interval (ms)
if (currentMillis - previousMillis > interval) {
// saves the time at which it last measured
do {
  checksensor(); // Tests which Sensor is currently connected
  // Sets the specific units, use Celsius or Fahrenheit here.
  // TODO: Move this into the "changeable lines"
  BME280::TempUnit tempUnit(BME280::TempUnit_Celsius);
  BME280::PresUnit presUnit(BME280::PresUnit_Pa);
  // reads sensordata
  bme.read(var_pres, var_temp, var_hum, tempUnit, presUnit);
  // Converts the input into useable variables
  char var_Ctemp[10];
  char var_Chum[10];
  char var_Cpres[20];
  dtostrf(var_temp, 1, 1, var_Ctemp);
  dtostrf(var_hum, 1, 1, var_Chum);
  dtostrf(var_pres, 1, 1, var_Cpres);
  // If the sensor functioned as it should
  if ((!isnan(var_hum)) && (!isnan(var_temp))) {
    Serial.println("Sensor has been read successfully");
    // TODO: Use the Pressuremeasurement to calculate the height etc.
    wififunction();
    // Sucks if you review your code after some time and didn't add comments..
  connectloop = 0; // reset the variable for the next time this runs (used in wififunction())
  dbconnect();
  dbupload(var_Ctemp, var_Chum, var_Cpres);
  i++;
} while ((!isnan(var_hum)) && (!isnan(var_temp)) && (i < 1));
i = 0; // reset the loop for the next time this runs
// close db connection
dbconn = 0;// reset the variable for the next time this runs (used in dbconnect())
conn.close();
Serial.println("Closed db connection");
// disconnect wifi to save power
wificonnect = 0; // reset the variable for the next time this runs (used in wififunction())
WiFi.disconnect();
Serial.println("Closed wifi connection");
Serial.println("Waiting for the next loop...");
Serial.println("");
// TODO: use deepsleep
delay(20); // Workaround for an internal ESP8266 issue
void checksensor() {
Serial.println("Searching for sensors...");
//BME/BMP280
while (!bme.begin())
Serial.println("Could not find BME280 sensor!");
switch (bme.chipModel())
case BME280::ChipModel_BME280:
Serial.println("Found BME280 sensor! Success.");
case BME280::ChipModel_BMP280:
Serial.println("Found BMP280 sensor! No Humidity available.");
default:
Serial.println("Found UNKNOWN sensor! Error!");
// Connect to WiFi
void wififunction() {
if(WiFi.status() != 3 && WiFi.status() != 0){
do {
Serial.println("###WiFi NOT Connected##");
WiFi.config(ip, gateway, subnet);
Serial.println("Initialising connection");
Serial.print(F("Setting static ip to : "));
Serial.println(ip);
Serial.println("");
WiFi.mode(WIFI_STA); // Set WiFi to Clientmode
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
wificonnect = 1;
connectloop++;
} while ((wificonnect != 1) && (connectloop < 6)); // Aborts after 5 times to save power
Serial.println("Wifi has been connected successfully");
else{
Serial.println("###WiFi is Connected##");
Serial.println("");
Serial.print("Assigned Hostname: ");
Serial.println(WiFi.hostname());
Serial.println("");
Serial.print("Assigned IP: ");
// Connect to Database
void dbconnect() {
int j = 0;
do {
Serial.println("Connecting to Database...");
conn.connect(server_addr, 3307, user, password); // 3306 = standard port
dbconn = 1;
j++;
} while ((dbconn != 1) && (j < 6));
j = 0; // reset the loop for the next time this runs
Serial.println("Db has been connected successfully");
void dbupload(char* var_Ctemp, char* var_Chum, char* var_Cpres) {
// Upload the data
// print query into the serial monitor for easy debugging
sprintf(query, INSERT_SQL, sensorname, var_Ctemp, var_Chum, var_Cpres);
Serial.println("Recording data..");
Serial.println(query);
Serial.println(var_Ctemp);
// run query
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
cur_mem->execute(query);
delete cur_mem;
¿Donde esta el fallo?
Moderador:
Bienvenido al foro Arduino en Español.
Lamento saludarte y luego tener que llamarte la atención por dos faltas.
1)Tu post debió postearse en Microprocesadores pero ya esta resuelto. La próxima presta atención, existe una sección determinada para cada tipo de consulta.
2)Tu código debió incluir etiquetas.
Por favor edita tu post inicial, corta el código y luego haz click en </> y luego pega el codigo y lucirá correctamente.
Lee las normas del foro por favor.
Gracias.
El código tiene además caracteres especiales como si lo hubieras copiado de una web y luego pasteado aquí.
