Esp8266 board not working
Hello
I got an esp8266 board, after burning the code to the board, it refuses to print out on the serial monitor
The code I used was the led blinking example which the led blinks and it outputs to the serial monitor..the led blinks till I open up the serial monitor and it stops blinking till I close the serial monitor
#include <Arduino.h>
#define LED 2
  pinMode(LED, OUTPUT);
  digitalWrite(LED, HIGH);
  Serial.println("LED is on");
  digitalWrite(LED, LOW);
  Serial.println("LED is off");
What code?
#define LED 2
Is there a built-in LED on pin 2?
Yes
It blinks well when the code is running, but when I try to open the serial monitor it stops and only continues when I close it
Try disabling the LED code and seeing if the serial monitor works without the LED code.
the pin mode and both digital writes
I tried the board with an ultrasonic sensor (HCSRO4) to print the distance between the sensor and object it didn't print out anything
Let's work on one thing at a time though
Oh I'm not getting you
See comment 6
It's not still printing
Did you set the correct baud rate on the serial monitor?
Yes 115200
That's not the same rate that's in your code
I used the 9600 too
Used 115200
Same thing
I should remove the line?
@mozman777
Affirmative
Still not working
The board is blinking but not printing
Both NL & CR
