"Dont use delay()" is not an option. I actually have some code instead of delay() where my android app is connecting to the arduino via bluetooth module.
the code is:
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <SoftwareSerial.h>
#define BUTTONPIN D3
#include <string.h>
#include <stdio.h>
SoftwareSerial mySerial(D1,D2);
String Data = "";
String password1 = "";
String ssid1 = "";
int button = 0; // 0 isrealeashed, 1 is pressed
char inChar;
int READINGSTATUS = -1;
char str[80] = "This is - www.tutorialspoint.com - website";
const char s[2] = ":";
char *token;
const char* ssid = "***";
const char* password = "**";
const char* host = "***.com";
const int httpsPort = 3245;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
void parseInput() {
int i=0;
int pos = 0;
if(Data[0] == '<' && Data[Data.length()] == '>' ) {
ζ}
for(i=0; i<Data.length(); i++) {
str[pos] = Data[i];
pos++;
token = strtok(str, s);
password1 = token;
while( token != NULL ) {
Serial.println(token );
token = strtok(NULL, s);
ssid1 = token;
Serial.println("");
Serial.print("SSID: ");
Serial.println(ssid1);
Serial.print("PASSWORD: ");
Serial.println(password1);
Serial.println("Serial input was read sucesfully.");
// Setting up Serial communication
mySerial.begin(9600);
// Setting up pins
pinMode(BUTTONPIN, INPUT);
// Blinking red -waiting to connect to a bluetooth device.
// Waiting to reveice data from bluetooth.
Serial.println(" Android device message:");
while(1) {
delay(100);
if (mySerial.available() > 0) {
char myc = mySerial.read();
Data.concat(myc);
Serial.print(myc);
Serial.print(" ");
if (myc == '>') {
parseInput();
mySerial.write("Everything is ok");
//Serial.print("Android said: ");
//Serial.println(Data);
Serial.println("Connecting with: ");
char id[ssid1.length()+1];
ssid1.toCharArray(id, ssid1.length()+1);
//password.toCharArray(password1, );
// Connecting to WIFI hotspot
Serial.println(id);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Use WiFiClientSecure class to create TLS connection
WiFiClientSecure client;
Serial.print("connecting to ");
Serial.println(host);
if (!client.connect(host, httpsPort)) {
Serial.println("connection failed");
return;
if (client.verify(fingerprint, host)) {
Serial.println("certificate matches");
Serial.println("certificate doesn't match");
String url = "/";
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
if (line.startsWith("{\"state\":\"success\"")) {
Serial.println("esp8266/Arduino CI successfull!");
Serial.println("esp8266/Arduino CI has failed");
Serial.println("reply was:");
Serial.println("==========");
Serial.println(line);
Serial.println("closing connection");
int buttonState = digitalRead(BUTTONPIN);
if( buttonState == 1) {
Serial.println("Button is releashed!");
}else {
Serial.println("Button is pressed!");
//Serial.println("---> Incoming byte!");
Serial.print(myc);
Serial.print(" ");
delay(50);
