ESP8266 circuit
Hello guys
My ESP8266-01 circuit is like that i know maximum 3.3V can be applied to ESP but for Rx pin of ESP i apply 5V (directly from the digital output of atmega328p) .I have tried to divide voltage using 10k/20k resistors however it did not work in that condition that's why i removed the resistors and it works quite fine for 2 months. As i guess it does not harm esp because output current of I/O pins is small. My first question if i use the circuit like in the figure,will it make any trouble in the future for esp8266. Second question is Should i use a buffer to reduce the voltage something like 'NC7SZ125P5XTR-ND'.
Use a logic level shiftier
Mark
You need to get as better grasp on current and voltage, then also look into source and sink current. What kind of esp do you have? Is it a module that already has a level shifter on board? What controller are you using? Is it a 3v controller?
Normally, logic circuits don't like having nearly double the operating voltage applied to them. They tend to simply quit working.....forever
Is this a "bare" ESP board.
Did you only use a divider on the RX pin of the ESP.
Why didn't you use the recommended 1k:2k values.
Leo..
You can also look at how Adafruit solve this problem on their Huzzah ESP8266 breakout using a 1n4148 diode:
https://learn.adafruit.com/assets/24745
Wawa:
Leo..
Yes it is normal ES8266-01 I just used the divider on the RX pin. I did not know 1k:2k values are recommended that's why i have used 10k:20k
tinman13kup:
I am using atmega328p and supplying it with 5V
so are 1k:2k resistors best option ?
I hope you not running it at 5 volts it will not last long at five volt power
I am not running esp with 5v i am just applying 5v to RX pin of esp
