ESP8266 Client doesn't reflect switch state.
I am using the instructables ESP8266 as a microcontroller code as a starting point to which I have added some code to get the client (Ipad) to show the state of a switch attached to the WeMos board.
The original code worked well and I was able to change the inbuilt LED on the WeMos board to on and off as well as get it to send a message that the LED was either on or off.
I added a switch attached to the board where I wanted to observe its on/off status on the client (Ipad). However, changing this switch does not effect the switch state observed on the Ipad display. I have checked that the voltage changes on Pin 6 (Digital pin 12) using the switch.
There is something obviously wrong with my approach, which is most likely my inexperience with server/client methods. Can anyone suggest where I have made an error/s?
This is a first attempt to get something working and once I get this going I will incorporate a simpleTimer to poll it.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
//http://www.instructables.com/id/ESP8266-As-a-Microcontroller/
//Ipad on Safari to 192.168.4.1
//Note that this uses the WeMos board
const char* ssid = “ESP”;
const char* password = “123456789”;
const int DIGITAL_PIN = 12; // Digital pin to be read (is marked D6 on board)
String Vsw;
String form = “OffOn”;
ESP8266WebServer server(80);
void handle_led() {
// get the value of request argument “state” and convert it to an int
int state = server.arg(“state”).toInt();
digitalWrite(BUILTIN_LED, state);
server.send(200, “text/plain”, String("LED is now ") + ((state)?“off”:“on”) + " Switch " + (Vsw));
void setup(void) {
pinMode(DIGITAL_PIN, INPUT_PULLUP);
pinMode(BUILTIN_LED, OUTPUT); // initialize onboard LED as output
digitalWrite(BUILTIN_LED, HIGH);//note that this sets led off
WiFi.softAP(ssid, password);
server.on("/", {
server.send(200, “text/html”, form);
server.on("/led", handle_led);
// Start the server
server.begin();
void loop(void) {
// check for incoming client connections frequently in the main loop:
server.handleClient();
digitalRead(DIGITAL_PIN);
if (DIGITAL_PIN ==LOW)
{Vsw=“Closed”;
{Vsw=“Open”;
This causes me some confusion.
Yes, it does get a bit confusing but I'm referring to GPIO12 which is marked D6 on board see:
http://www.wemos.cc/Products/d1_mini.html
I would like to be able to do a request from the client to examine the switch state but because my HTML knowledge is limited I'm unsure of how to include that in the String form.
In that way I would not need to continually poll the void loop but only do a switch state check when requested. However, I'm still mystified why the switch state doesn't show a change on the client Ipad.
The response to the server
server.send(200, "text/plain", String("LED is now ") + ((state)?"off":"on") + " Switch " + (Vsw)); is
LED is now on Switch Open
where on changes to off as requested but Open never changes to Closed despite changing switch state.
Any ideas anyone???
This is your problem.
  {Vsw="Closed";
  {Vsw="Open";
It should be like this.
  byte pinState = digitalRead(DIGITAL_PIN);
  if (pinState == LOW)
  {Vsw="Closed";
  {Vsw="Open";
...or this:
  if (digitalRead(DIGITAL_PIN) == LOW)
  {Vsw="Closed";
  {Vsw="Open";
Or even
Vsw = digitalRead(DIGITAL_PIN) ? "Open" : "Closed";
Thanks so much SurferTim that fixed it.
It shows that too much time spent using Basic in the MCS Bascom environment has made my C a bit wanting. I must say that Bascom still has its place particularly to do simple minimal projects such as those requiring very low power consumption - it can be applied to any of the AVG micros.
I am also very impressed with the WeMos esp8266 board particularly when I remember the frustration spent with the hairy ESP8266-01 board.
Now that this hurdle has been overcome - on to the next.
Since the above, another post has come in from Whandall, thanks for that too.
