ESP8266 Cloud Firmware Update Fail
I have an ESP8266 and it was at the level that it can do a Cloud Firmware update, so after getting on the internet with my wireless router I issued AT+CIUPDATE
I got the 4 expected lines then garbage for the next 10 minutes, changed the speed from 9600 to everything else, just more garbage.
Went and watched the news, came back, garbage.
Finally I killed the power to the chip and then plugged it back again, same garbage, looks like it restarted right where it left off.
Pulled the GPIO and Rest pins to ground to hardware reset, the garbage stopped but no response to the keyboard. Pulled the power, and when I powered on again the garbage started again!!!
Anyone have a clue how to get out of this cycle?
Garbage means the baud rate is wrong.
Try reading at 74880 baud. You'll need to use a Serial monitor outside of the IDE like HTerm or CoolTerm.
This will allow you to read the bootloader text.
Old versions use 115200 baud, mine are newer and use 9600 baud for the AT commands. Have you manually changed the baud to some custom value using AT commands, as this is saved between restarts.
Pulling pin 0 low and resetting starts Flash mode, nothing is printed to serial apart from the boot loader info. Flash mode may not be usable from power up, maybe only restart, I'll have to check further.
If all else fails, re-flash the firmware manually I guess.
