Hello all
I found online a pice of code thar does exectly what i need it to do but it only runs on a ESP8266, thing that i don't have.
Question:
Can anyone help me convert it to work with my Uno ??
Thank you in advanced
Xmodpt
* Curing station source code.
* Up = 271
* Down = 460
* Left = 715
* Right = 896
* Press = 1024
#include <Wire.h>
#include "OLED.h"
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
* AD-value for 5-way tactile joystick connected to different resistors.
#define button_up 271
#define button_down
#define button_left 715
#define button_right 896
#define button_press A0
* Pin settings
#define uvlight 14
#define led 13
#define motor 12
#define button A0
OLED display(4, 5);
bool menuActive = false;
bool sequence_active = false;
int val;
int len;
char text[20];
int text_size;
int value = 0;
int time_setting1 = 300;
int time_setting2 = 600;
int time_setting3 = 900;
int time_counter = 0;
int time_display_minutes = 0;
int time_display_seconds = 59;
int active_menuitem = 1;
* PWM Pre-sets
int motor_pwm = 600;
int uvlight_pwm = 1023;
//Serial.begin(115200);
//Serial.println("Serial port debug");
pinMode(uvlight, OUTPUT);
pinMode(motor, OUTPUT);
pinMode(button, INPUT);
pinMode(led, OUTPUT);
// Initialize display
display.begin();
display.off();
display.on();
display.print(" Curingbox V1", 1, 0);
display.print(" -> 5 min", 3, 0);
display.print(" 10 min", 4, 0);
display.print(" 15 min", 5, 0);
analogWrite(uvlight, 0);
analogWrite(motor, 0);
digitalWrite(led, 1);
menuActive = true;
while(menuActive){
delay(10);
val = analogRead(button);
switch(active_menuitem){
case 1:
if(val > button_up-10 && val < button_up+10){
active_menuitem = 2;
if(val > button_down-10 && val < button_down+10){
if(val > button_press){
menuActive = false;
time_counter = time_setting1;
case 2:
display.print(" 5 min", 3, 0);
display.print(" -> 10 min", 4, 0);
active_menuitem = 3;
menuActive = false;
time_counter = time_setting2;
case 3:
display.print(" -> 15 min", 5, 0);
menuActive = false;
time_counter = time_setting3;
//Debounce
while(val > 50){
//Start sequence
//clean menu
display.print(" Time: ", 3, 0);
display.print(" UVlight: ", 4, 0);
display.print(" Motor: ", 5, 0);
digitalWrite(led, 0);
for(int i = 0; i < motor_pwm+1; i++){
analogWrite(motor, i);
itoa(i, text, 10);
display.print(text, 5, 10);
delay(5);
for(int i = 0; i < uvlight_pwm-10; i=i+10){
analogWrite(uvlight, i);
itoa(i, text, 10);
display.print(text, 4, 10);
delay(5);
//Main loop
sequence_active = true;
while(sequence_active){
time_display_minutes = time_counter/60;
itoa(time_display_minutes, text, 10);
if(time_display_minutes > 9){
display.print(text, 3, 9);
display.print(text, 3, 10);
display.print(":", 3, 11);
itoa(time_display_seconds, text, 10);
display.print(text, 3, 12);
itoa(uvlight_pwm, text, 10);
itoa(motor_pwm, text, 10);
if(val > 1000){
while(val > 1000){
time_counter = 1;
//Clean values
time_counter--;
if(time_display_seconds == 0){
time_display_seconds = 60;
time_display_seconds--;
if(time_counter < 1){
