Esp8266 code doesn't work on Feather Huzzah
Hey All,
I've got some code that works as intended on a generic esp8266 board. I want to use this code on a Feather Huzzah.
The pinouts are different between the two boards so I update that before uploading. I change the board in the board manager and upload. As far as I can tell that's all I need to change.
The Huzzah starts up and connects to the wifi network but after a second or two it drops and the board resets/restarts. Before it crashes the serial monitor sends out a line of gibberish. I tried looking at it at different baud rates but it kept coming as gibberish.
How can I make this work on the Huzzah?
My code is in tabs. I've pasted each one separately
// coded for Feather Huzzah
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <LEDFader.h>
#include <stdlib.h>
#include <ArduinoJson.h>                                      // https://github.com/bblanchon/ArduinoJson
// The following pins are PWM for the Feather Huzzah
#define LED_PIN 3
#define LED_PIN2 12
#define LED_PIN3 13
#define fan 14
// The following pins are PWM for the generic esp8266
// #define LED_PIN 4
// #define LED_PIN2 14
// #define LED_PIN3 15
// #define fan 12
char message_buff[100];
#define FADE_UP_TIME 10
#define FADE_DOWN_TIME 3000
#define FADE_TIME 3000
#define DIR_UP 1
#define DIR_DOWN -1
LEDFader  led;
LEDFader led2;
LEDFader led3;
// #define LED_NUM 3
int direction = DIR_UP;
float bookshelfTemp = 0;
int brightness = 0;
int lastBrightness = 0;
unsigned long currentMillisTemps = 0;
unsigned long previousMillisTemps = 0;  // will store last time LED was updated
const long intervalTemps = 10000;
// Update these with values suitable for your network.
const char* ssid = "XXX";
const char* password = "XXX";
const char* mqtt_server = "192.168.1.217";
WiFiClient espClient;
PubSubClient client(espClient);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(ledControl);  //callback
  pinMode(3, OUTPUT);  // Initialize the BUILTIN_LED pin as an output
  pinMode(10, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(15, OUTPUT);
  pinMode(14, OUTPUT);
  led = LEDFader(LED_PIN);
  led.fade(0, 255);
  led2 = LEDFader(LED_PIN2);
  led2.fade(0, 255);
  led3 = LEDFader(LED_PIN3);
  led3.fade(0, 255);
  Serial.println("Bookshelf 8/8/2023 - this script is configured for generic esp8266");
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  // WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  WiFi.hostname("BOOKSHELF");
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str())) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("/bookshelf/motionSensor", "Reconnected to Hanging Lamp");
      client.subscribe("/bookshelf/lamp1");
      client.subscribe("/bookshelf/lamp2");
      client.subscribe("/bookshelf/lamp3");
      client.subscribe("/bookshelf/lamp4");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void ledControl(char* topic, byte* payload, unsigned int length) {
  StaticJsonDocument<256> doc;  // Allocate memory for the doc array.
  deserializeJson(doc, payload, length);
  // Serial.print("Message arrived: ["); Serial.print(topic); Serial.println("]");             // Prints out anything that's arrived from broker and from the topic that we've subscribed to.
  int i;
  for (i = 0; i < length; i++) message_buff[i] = payload[i];
  message_buff[i] = '\0';  // We copy payload to message_buff because we can't make a string out of payload.
  String modeBrightness = String(message_buff);
  modeBrightness = modeBrightness.toInt();
  if (strcmp(topic, "/bookshelf/lamp1") == 0) {  // Returns 0 if the strings are equal, so we have received our topic.
    uint16_t modeBrightness = doc["lamp1Brightness"];
    Serial.print("lamp1ModeBrightness: ");
    Serial.println(modeBrightness);
    led.fade(255, 500);
    // if (modeBrightness == 0) { digitalWrite(4, LOW); }
  if (strcmp(topic, "/bookshelf/lamp2") == 0) {  // Returns 0 if the strings are equal, so we have received our topic.
    uint16_t modeBrightness = doc["lamp2Brightness"];
    Serial.print("lamp2ModeBrightness: ");
    led2.fade(modeBrightness, 500);
  if (strcmp(topic, "/bookshelf/lamp3") == 0) {  // Returns 0 if the strings are equal, so we have received our topic.
    uint16_t modeBrightness = doc["lamp3Brightness"];
    Serial.print("lamp3ModeBrightness: ");
    led3.fade(modeBrightness, 0);
  if ((strcmp(topic, "/bookshelf/fan") == 0) && ((char)payload[0] == '0')) {
    digitalWrite(fan, LOW);
    Serial.println("FAN OFF");
    client.publish("/bookshelf/fan", "off");
  if ((strcmp(topic, "/bookshelf/fan") == 0) && ((char)payload[0] == '1')) {
    digitalWrite(fan, HIGH);
    Serial.println("FAN ON");
    client.publish("/bookshelf/fan", "on");
  led.update();
  led2.update();
  led3.update();
  if (!client.connected()) { reconnect(); }
  client.loop();
GPIO pins 6 to 11 are used for the flash memory interface.
