Hi everyone!
I'm completely beginner in programing i just wonder how can i merge this two programs in to one!
My goal is to see the time in my browser from my ESP device while i can controll my LEDs!
So how can a I make this?
Program number one:
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ezTime.h>
Timezone myLocalTime;
const char* ssid = "..."; //SSID of wifi network
const char* password = "...";// Password for wifi network
// config static IP
ESP8266WebServer server(80);
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
// Print local IP address and start web server
// WiFi configuration
WiFi.softAPdisconnect(true);
WiFi.mode(WIFI_STA);
WiFi.disconnect();
WiFi.begin(ssid, password);
// Wait for connection
// Starting Webserver
server.begin();
// Webserver handles
server.on("/", handleRoot);
// Set desired time zone for Timezone object declared in the beginning
myLocalTime.setLocation(F("de")); // set your time zone
// Sync NTP time for ezTime library
waitForSync();
delay(2000);
server.handleClient();
delay(50);
// WebServer handles:
void handleRoot() {
server.send(200, "text/html", getDefaultPage());
// webServer handles END
// Default page
String getDefaultPage() {
String page = "\n\n\n\n\n nodeMCU\n <meta charset="utf-8">\n\n\n\n
Led iranyitas
\nIdo: ##ido##
\nDatum: ##datum##
\n\n\n ";page.replace("##ido##", myLocalTime.dateTime("H:i:s"));
page.replace("##datum##", myLocalTime.dateTime("d.m.Y"));
return page;
// End Default page
Program number two:
// Load Wi-Fi library
// Replace with your network credentials
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output26State = "off";
String output27State = "off";
String output15State = "off";
// Assign output variables to GPIO pins
const int output26 = D8;
const int output27 = D13;
const int output15 = D13;
// Current time
// Previous time
// Initialize the output variables as outputs
pinMode(output26, OUTPUT);
pinMode(output27, OUTPUT);
pinMode(output15, OUTPUT);
// Set outputs to LOW
digitalWrite(output26, LOW);
digitalWrite(output27, LOW);
digitalWrite(output15, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print("Csatlakozás... ");
Serial.println(ssid);
Serial.print(".");
Serial.println("");
Serial.println("WiFi csatlakozva.");
Serial.println("IP cím: ");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
previousTime = currentTime;
Serial.println("Új készülék."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /26/on") >= 0) {
Serial.println("GPIO 26 on");
output26State = "on";
digitalWrite(output26, HIGH);
} else if (header.indexOf("GET /26/off") >= 0) {
Serial.println("GPIO 26 off");
} else if (header.indexOf("GET /27/on") >= 0) {
Serial.println("GPIO 27 on");
output27State = "on";
digitalWrite(output27, HIGH);
} else if (header.indexOf("GET /27/off") >= 0) {
Serial.println("GPIO 27 off");
}else if (header.indexOf("GET /15/on") >= 0) {
Serial.println("GIPO 15 off");
output15State = "on";
digitalWrite(output15, HIGH);
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #555555;}</style></head>");
// Web Page Heading
client.println("<body><h1>Led iranyitas</h1>");
// Display current state, and ON/OFF buttons for GPIO 26
client.println("<p>1 - es LED - State " + output26State + "</p>");
// If the output26State is off, it displays the ON button
if (output26State=="off") {
client.println("<p><a href=\"/26/on\"><button class=\"button\">BE</button></a></p>");
client.println("<p><a href=\"/26/off\"><button class=\"button button2\">KI</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 27
client.println("<p>2 - es LED - State " + output27State + "</p>");
// If the output27State is off, it displays the ON button
if (output27State=="off") {
client.println("<p><a href=\"/27/on\"><button class=\"button\">BE</button></a></p>");
client.println("<p><a href=\"/27/off\"><button class=\"button button2\">KI</button></a></p>");
client.println("</body></html>");
client.println("<p>2 - es LED funkcio (villog) - State " + output15State + "</p>");
if (output15State=="off") {
client.println("<p><a href=\"/15/on\"><button class=\"button\">BE(villog)</button></a></p>");
client.println("<p><a href=\"/15/off\"><button class=\"button button2\">KI</button></a></p>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Készülék lecsatlakova.");
Serial.println("");
