What is the error? Does it crash with a watchdog timer timeout? If so you may need a shorter timeout on the serial read. The readBytesUntil() will wait until there is data or the serial timeout.
// ESP32 example using HardwareSerial library to access Serial port 2 (pins 16 and 17)
#define SERIAL_BAUD 115200
HardwareSerial* refSer;
//Initialize serial port 0
Serial.begin(SERIAL_BAUD);
delay(2000);
Serial.println("ESP32 HardwareSerial test port 2 pins 16 and 17");
//Initialize serial port 2
refSer = new HardwareSerial(2);
refSer->begin(SERIAL_BAUD, SERIAL_8N1);
while (refSer->available() > 0) {
uint8_t byteFromSerial = refSer->read();
Serial.write(byteFromSerial);
while (Serial.available() > 0) {
uint8_t byteFromSerial1 = Serial.read();
refSer->write(byteFromSerial1);
serial monitor displays
08:46:35.119 -> ESP32 HardwareSerial test port 2 pins 16 and 17
08:46:43.696 -> test1
08:46:48.940 -> rest 2
08:46:53.331 -> 1234567890
08:46:58.033 -> abcdefgh
test using ESP8266 ESP12E transmit using serial 1 pin 17 (D4) TXD1
note: no RXD1 pin available
// ESP8266 example using HardwareSerial library to transmit using Serial port 1 pins TXD1 17 (no RXD1)
delay(2000);
Serial.println("\nESP8266 HardwareSerial transmit test port 1 pin TXD1 17");
//Initialize serial port 1
refSer = new HardwareSerial(1);
Serial.write(byteFromSerial1);
ESP8266 serial monitor
09:16:19.888 -> ESP8266 HardwareSerial transmit test port 1 pin TXD1 17
09:19:20.191 -> esp8266 test 1
09:19:26.044 -> test2
09:19:30.640 -> 1234567890
09:19:35.582 -> abcdefghijk
connected to ESP32 for test output
esp8266 test 1
test2
1234567890
abcdefghijk
