Hey Guys, I working on a project where I'm sending UDP packets.
But for some reason, the ESP crashes when it needs to sends a second packet, in a different part of the code, it craches at:
sprintf(buffer, "OKE"); UDP.write(buffer);
#include <Arduino.h>
#include "wifiHandler.h"
#include <eepromHandler.h>
WiFiUDP UDP;
byte macRecieved[6];
uint8_t sizeMac = 17;
uint8_t sizeResponse = 2;
char lastTwoChars[2];
const char* SSID = "networkName";
const char* PSW = "networkPassword";
unsigned int localUdpPort = 4210; // local port to listen on
char incomingPacket[255]; // buffer for incoming packets
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
wifiHandler hotspot;
hotspot.setupSoftAp();
eepromHandler eeprom;
eeprom.saveData(SSID, PSW, PARAMETER_SIZE_IN_BYTES);
eeprom.dumbData();
UDP.begin(localUdpPort);
Serial.print("Local port: ");
Serial.println(UDP.localPort());
int packetSize = UDP.parsePacket();
for (uint8_t i = 0; i < packetSize; i++) {
macRecieved[i] = 0xFF;
if (packetSize)
int len = UDP.read(incomingPacket, 255);
Serial.printf("Length is %d\r\n", len);
if (len > 0)
incomingPacket[len] = 0;
if (len == sizeMac){
sscanf(incomingPacket, "%2hhx:%2hhx:%2hhx:%2hhx:%2hhx:%2hhx",
&macRecieved[0], &macRecieved[1], &macRecieved[2], &macRecieved[3], &macRecieved[4], &macRecieved[5]);
if(macRecieved[0] < 0xFF && macRecieved[1] < 0xFF && macRecieved[2] < 0xFF && macRecieved[3] < 0xFF && macRecieved[4] < 0xFF && macRecieved[5] < 0xFF){
Serial.printf("Robot with address: %02hhX%02hhX asking for data\n", macRecieved[4], macRecieved[5]);
// send back a reply, to the IP address and port we got the packet from
UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
char buffer[PARAMETER_SIZE_IN_BYTES * 2 + 3];
sprintf(buffer, "%s / %s", SSID, PSW);
UDP.write(buffer);
UDP.endPacket();
for (uint8_t i = 0; i < sizeof(macRecieved) - 1; i ++){
} else if (len == sizeResponse){
if (incomingPacket[0] == SSID[strlen(SSID) - 1] && incomingPacket[1] == PSW[strlen(PSW) - 1]){
Serial.printf("ssid last char: %c psw last char: %c \r\n", SSID[strlen(SSID) - 1], PSW[strlen(PSW) - 1]);
Serial.printf("IP: %s port: %d", UDP.remoteIP().toString().c_str(), UDP.remotePort());
char buffer[4];
UDP.write(buffer);
UDP.endPacket();
Serial port:
Length is 17
Robot with address: 1EE7 asking for data
Length is 2
ssid last char: e psw last char: d
IP: 192.168.1.100 port: 4210
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (9):
epc1=0x40205eca epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000003 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd60 end: 3fffffc0 offset: 0190
3ffffef0: 3ffee750 00000020 3ffefe14 401008da
3fffff00: 3ffffe74 3ffefe14 3fffff30 3ffee8ac
3fffff10: 3ffee750 3ffefe14 3ffee858 40201303
3fffff20: 3ffee853 3ffee854 000003fb 4020ef04
3fffff30: 40206518 6401a8c0 00000000 656e202f
3fffff40: 72657774 6361576b 6f777468 0064726f
3fffff50: 4020216c 3ffe8887 3ffee8ac 402026a4
3fffff60: 007a1200 87b34f01 3ffee800 40202854
3fffff70: 00000000 40206518 6401a8c0 402029c8
3fffff80: 0000006d 00000000 00000001 40100164
3fffff90: 3fffdad0 00000000 3ffee924 3ffee938
3fffffa0: 3fffdad0 00000000 3ffee924 4020315c
3fffffb0: feefeffe feefeffe 3ffe85e8 40100c61
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00046080
~ld
I did some reading, and they say it has to do with memory, but I don't see how because I'm sending, and not receiving data.
