Esp8266 data logger chart js dynamic chart help
Hi guy I am building a data logger and want to display my values in chart js from local CVS file .
The issue i got is my chart is not updated at interval I need to refresh the page I am a beginner at programming any help would be appreciated thank you this is my code it runs and work but need interval function.
$(document).ready(function () {
$.get('./temp.csv', {'_': $.now()}, function(csvString) {
    var data = Papa.parse(csvString).data;
    var timeLabels = data.slice(1).map(function(row) { return row[0]; });
    var datasets = [];
    for (var i = 1; i < data[0].length; i++) {
      datasets.push(
          label: data[0][i], // column name
          data: data.slice(1).map(function(row) {return row[i]}), // data in that column
          fill: true // `true` for area charts, `false` for regular line charts
    // Get container for the chart
    var ctx = document.getElementById('chart-container').getContext('2d');
    new Chart(ctx, {
      type: 'line',
      data: {
        labels: timeLabels,
        datasets: datasets,
      options: {
        title: {
          display: true,
          text: TITLE,
          fontSize: 14,
        legend: {
          display: SHOW_LEGEND,
        maintainAspectRatio: false,
        scales: {
          xAxes: [{
            scaleLabel: {
              display: X_AXIS !== '',
              labelString: X_AXIS
            gridLines: {
              display: SHOW_GRID,
            ticks: {
              maxTicksLimit: 10,
              callback: function(value, index, values) {
                return value.toLocaleString();
          yAxes: [{
            stacked: false, // `true` for stacked area chart, `false` otherwise
            beginAtZero: true,
            scaleLabel: {
              display: Y_AXIS !== '',
              labelString: Y_AXIS
            gridLines: {
              display: SHOW_GRID,
            ticks: {
              maxTicksLimit: 10,
              beginAtZero: BEGIN_AT_ZERO,
        tooltips: {
          displayColors: false,
          callbacks: {
            label: function(tooltipItem, all) {
              return all.datasets[tooltipItem.datasetIndex].label
                + ': ' + tooltipItem.yLabel.toLocaleString();
        plugins: {
          colorschemes: {
              Replace below with any other scheme from
              https://nagix.github.io/chartjs-plugin-colorschemes/colorchart.html
            scheme: 'brewer.DarkTwo5'
How is this an arduino question?
How is the file updated?
Hi Mate my Esp8266 logs the temp to spiffs CVS file and my index html and java script fetches the file for my webserver so I just need to get a interval function in side my java script to show my data dynamically my ESP is programed in Arduino ide .
I don't relay know where to ask this type of question I just thought maybe someone would be kind enough to help me out.
Something similar to this (setInterval(fetch Data temp.cvs, 1000);
Thanks
The simplest way If you want the browser to refresh from time to time is to issue the request every 5 seconds for example
Place inside the <head> element to refresh page after 5 seconds:
<meta http-equiv="refresh" content="5">
Thanks for that will give it a go, appreciate the help
