ESP8266 data uploading to sql or hosting
Hello everybody,
I am new here, so I don’t know much about this forum, although I have tried my best to select the relevant forum.
I am working on a project, where I am trying to upload my sensors’ data on a web server. I am using ESP8266 in its purest form, not using any breakout board like NodeMCU.
I’m using this ESP8266: ESP8266 Pinout, Datasheet, Features & Applications - The Engineering Projects
I have successfully connected it with WiFi and it’s getting the webpage. Now my question, How can I upload my sensors’ data on my web server??
I don’'t want the code, I just want to know the way to do it? Should I use FTP and upload txt files containing data or there’s any other way to store data in DB or hosting?
Thanks in advance. :slight_smile:
You can have your ESP send a request for a web page.
"http:myButtIsNotTelling.com/EnableHumidity.php?&chkYesNo=1"
The web server can take that request for a web page that has:
<?php
$chkYesNo = $_GET['chkYesNo'];
include 'db_connection.php';
$query = "UPDATE State SET EnableHumidity =" . $chkYesNo ;
$result = mysqli_query($con, $query);
mysqli_close($con);
is one way of doing the thing.
Or you can use MySQL Connector Arduino
Or you can do other things that are a bit more complicated.
Idahowalker:
Is it a secure way to send the data as parameter? It's too open, anyone can access it or update it (I think).
oliviasmithh900:
I use a RPi as a MQTT Broker. All the ESP32's connect to the RPi on a local network. The RPi connects, on a different network, to the internet.
I don't use the http thingy cause of the obvious issues.
Idahowalker:
Yeah Raspberry Pi is an easy option but it comes with a price so let's try some more luck with esp8266 as its low cost.
@oliviasmithh900
Banned as a sock puppet you may complain through official channels if you wish the account restored.
