ESP8266 doesn't connect to AWS-IOT (PubSubClient errorcode:-1))
Hi guys, i couldn't manage to connect my ESP8266 to my AWS IOT :frowning:
I cannot understand what i have done wrong, the secrets.h file has copy paste the code from TLS aws cerificates. So i'm sure that something in my code is wrong.
It connects to the wifi network, finds the local time, but when its time to establish a connection with the aws broker, first PubSubClient errorcode -1 appears and then -2
enercost_client_tutorial.ino (3.1 KB)
Before you ask, let me mention: In AWS policies have all required permissions attached to the thing's certificate.
 #include <WiFiClientSecure.h>
#include "secrets.h"
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <time.h>
// The MQTT topics that this device should publish/subscribe
#define AWS_IOT_PUBLISH_TOPIC   "buildings/C-1"
#define AWS_IOT_SUBSCRIBE_TOPIC "buildings/upd/B-1"
BearSSL::X509List ca_cert(AWS_CERT_CA);
BearSSL::X509List client_crt(AWS_CERT_CRT);
BearSSL::PrivateKey client_key(AWS_CERT_PRIVATE);
WiFiClientSecure net;
PubSubClient pubSubClient(AWS_IOT_ENDPOINT, 8883 , net);
void connectAWS()
  WiFi.mode(WIFI_STA);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.println("Connecting to Wi-Fi");
  while (WiFi.status() != WL_CONNECTED){
    Serial.print(".");
  // Create a message handler
 // pubSubClient.onMessage(messageHandler);
  Serial.print("Connecting to AWS IOT");
  while (!pubSubClient.connect(THINGNAME)) {
    Serial.print(".");
    delay(100);
  if(!pubSubClient.connected()){
    Serial.println("AWS IoT Timeout!");
    return;
  // Subscribe to a topic
  pubSubClient.subscribe(AWS_IOT_SUBSCRIBE_TOPIC);
  Serial.println("AWS IoT Connected!");
void publishMessage()
  StaticJsonDocument<200> doc;
  doc["building_id"] = "B-1";
  doc["device_id"] = "B-1";
  doc["device_loc"] = "Athens";
  doc["device_type"] = "Mother_sensor";
  doc["watt_value"] = 4.2;
  doc["watt_price_value"] = 0.20;
  doc["cng_value"] = 1.4;
  doc["cng_price_value"] = 0.16;
  doc["water_value"] = 10;
  doc["water_price_value"] = 0.001;
  char jsonBuffer[512];
  serializeJson(doc, jsonBuffer); // print to client
  pubSubClient.publish(AWS_IOT_PUBLISH_TOPIC, jsonBuffer);
void setCurrentTime() {
  configTime(2 * 3600, 0, "pool.ntp.org", "time.nist.gov");  //UTC
  Serial.print("Waiting for NTP time sync: ");
  time_t now = time(nullptr);
  while (now < 8 * 3600 * 2) {
    Serial.print(".");
  Serial.println("");
  struct tm timeinfo;
  gmtime_r(&now, &timeinfo);
  Serial.print("Current time: "); Serial.print(asctime(&timeinfo));
  Serial.println("client mother device");
  Serial.print("Connecting to "); Serial.print(WIFI_SSID);
  WiFi.waitForConnectResult(2000);
  Serial.print(", WiFi connected, IP address: "); Serial.println(WiFi.localIP());
  setCurrentTime();//for certificates not to be shown as expired
  net.setClientRSACert(&client_crt,&client_key);
  net.setTrustAnchors(&ca_cert);
  pubSubCheckConnect();
  publishMessage();
void pubSubCheckConnect() {
  if ( ! pubSubClient.connected()) {
    Serial.print("Enercost Client connecting to: "); Serial.print(AWS_IOT_ENDPOINT);
    while ( ! pubSubClient.connected()) {
      Serial.print(".");
      Serial.println(pubSubClient.state());
      pubSubClient.connect("enercost_dev_b1");
    Serial.println(" connected");
  pubSubClient.loop();
-2 means connection failed. As you use a TLS connection that either means the CA/certificate material you provide is wrong or your device doesn't have an internet connection at all.
