I tried using this code but for some reason the ESP doesn't recieve a message from MQTT, here the code that i use:
#include <WiFiManager.h>
#include <ESP8266WiFi.h>
#include <Ticker.h>
#include <PubSubClient.h>
#include <Wire.h>
#include <Adafruit_BME280.h>
#include <Adafruit_Sensor.h>
#include "NTP.h"
#include <WiFiUdp.h>
const int buttonPin = D7;
int buttonState = 0;
#define MQTT_HOST "***********"
#define MQTT_PORT ****
#define RelayPin1 D3
#define RelayPin2 D4
#define RelayPin3 D5
#define RelayPin4 D6
#define MQTT_SUB_Relay1 "esp-wemos-mini/2/relay1"
#define MQTT_SUB_Relay2 "esp-wemos-mini/2/relay2"
#define MQTT_SUB_Relay3 "esp-wemos-mini/2/relay3"
#define MQTT_SUB_Relay4 "esp-wemos-mini/2/relay4"
#define MQTT_PUB "esp-wemos-mini/2/data"
#define SEALEVELPRESSURE_HPA (1013.25)
WiFiUDP wifiUdp;
NTP ntp(wifiUdp);
WiFiManager wm;
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
Adafruit_BME280 bme;
float temperature = 0;
float humidity = 0;
float barometer = 0;
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
setup_wifi();
client.setServer(MQTT_HOST, MQTT_PORT);
client.setCallback(callback);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
digitalWrite(RelayPin1, HIGH);
digitalWrite(RelayPin2, HIGH);
digitalWrite(RelayPin3, HIGH);
digitalWrite(RelayPin4, HIGH);
ntp.begin();
ntp.timeZone(7,0);
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println("Connecting to Wi-Fi...");
WiFi.mode(WIFI_STA);
bool res;
res = wm.autoConnect("Test","password");
if(!res) {
Serial.println("Failed to connect");
// ESP.restart();
else {
//if you get here you have connected to the WiFi
Serial.println("connected");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void configModeCallback(WiFiManager *myWiFiManager)
// Called when config mode launched
Serial.println("Entered Configuration Mode");
Serial.print("Config SSID: ");
Serial.println(myWiFiManager->getConfigPortalSSID());
Serial.print("Config IP Address: ");
Serial.println(WiFi.softAPIP());
void callback(char* topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
if (String(topic) == MQTT_SUB_Relay1) {
Serial.print("Changing output to ");
if(messageTemp == "on"){
Serial.println("RelayPin 1 ON");
digitalWrite(RelayPin1, LOW); // Turn the LED on (Note that LOW is the voltage level
else if(messageTemp == "off"){
Serial.println("RelayPin 1 Off");
digitalWrite(RelayPin1, HIGH); // Turn the LED off by making the voltage HIGH
if (String(topic) == MQTT_SUB_Relay2) {
Serial.println("RelayPin 2 ON");
digitalWrite(RelayPin2, LOW); // Turn the LED on (Note that LOW is the voltage level
Serial.println("RelayPin 2 Off");
digitalWrite(RelayPin2, HIGH); // Turn the LED off by making the voltage HIGH
if (String(topic) == MQTT_SUB_Relay3) {
Serial.println("RelayPin 3 ON");
digitalWrite(RelayPin3, LOW); // Turn the LED on (Note that LOW is the voltage level
Serial.println("RelayPin 3 Off");
digitalWrite(RelayPin3, HIGH); // Turn the LED off by making the voltage HIGH
if (String(topic) == MQTT_SUB_Relay4) {
Serial.println("RelayPin4 ON");
digitalWrite(RelayPin4, LOW);
Serial.println("RelayPin4 OFF");
void(* resetFunc) (void) = 0;
void button() {
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if(buttonState == LOW) {
Serial.println("Restarting");
wm.resetSettings();
resetFunc();
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("MQTT connected");
if (client.connect("Alphamas")){
Serial.print("Attempting MQTT connection...");
client.subscribe(MQTT_SUB_Relay1);
client.subscribe(MQTT_SUB_Relay2);
client.subscribe(MQTT_SUB_Relay3);
client.subscribe(MQTT_SUB_Relay4);
}else{
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 5000) {
lastMsg = now;
ntp.update();
temperature = bme.readTemperature();
// Uncomment the next line to set temperature in Fahrenheit
// (and comment the previous temperature line)
//temperature = 1.8 * bme.readTemperature() + 32; // Temperature in Fahrenheit
// Convert the value to a char array
char tempString[8];
dtostrf(temperature, 1, 2, tempString);
Serial.print("Temperature: ");
Serial.println(tempString);
humidity = bme.readHumidity();
char humString[8];
dtostrf(humidity, 1, 2, humString);
Serial.print("Humidity: ");
Serial.println(humString);
barometer = bme.readPressure() / 100.0F;
char baroString[8];
dtostrf(barometer, 1, 2, baroString);
Serial.print("Barometer: ");
Serial.println(baroString);
Serial.print("Time: ");
Serial.println(ntp.formattedTime("%Y/%m/%d %T"));
char messageData[60];
sprintf(messageData, "%s, %s, %s, %s",ntp.formattedTime("%Y/%m/%d %T"),tempString,humString,baroString);
client.publish(MQTT_PUB, messageData, true);
delay(20000);
button();
Thanks
