ESP8266 e comandi AT
Ciao a tutti, sto cercando di inviare una richiesta GET al mio sito hostato su Altervista attraverso un ESP-01 per inviare alcuni dati come temperatura, umidità, ecc mediante il alcuni comandi AT
AT+CIPSTART="TCP","---",80
AT+CIPSEND=274
GET /Inseriamolo.php?temperatura=19.30&umidita=54.90&currentPressure=96372&dewPoint=9.75&Temperaturamassima=18.30&Temperaturaminima=18.30&Umiditamassima=53.90&Umiditaminima=53.90&Pressionemassima=96371&Pressioneminima=96371&dewPointmassimo=8.75&dewPointminimo=8.75HTTP/1.1
ma in risposta sulla seriale di arduino ricevo il seguente risultato.
OK
Recv 274 bytes
SEND OK
+IPD,1452:<!DOCTYPE html>
<!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
<!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
<!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
<!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
<head>
<title>Direct IP access not allowed | Cloudflare</title>
<meta charset="UTF-8" />
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
<meta name="robots" content="noindex, nofollow" />
<meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1" />
<link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
<!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
<style type="text/css">body{margin:0;padding:0}</style>
<!--[if lte IE 9]><script type="text/javascript" src="/cdn-cgi/scripts/jquery.min.js"></script><![endif]-->
<!--[if gte IE 10]><!--><script type="text/javascript" src="/cdn-cgi/scripts/zepto.min.js"></script><!--<![endif]-->
<script type="text/javascript" src="/cdn-cgi/scripts/cf.common.js"></script>
</head>
<body>
  <div id="cf-wrapper">
    <div class="cf-alert cf-alert-error cf-cookie-error" id="cookie-alert" data-translate="enab
+IPD,1452:le_cookies">Please enable cookies.</div>
    <div id="cf-error-details" class="cf-error-details-wrapper">
      <div class="cf-wrapper cf-header cf-error-overview">
        <h1>
          <span class="cf-error-type" data-translate="error">Error</span>
          <span class="cf-error-code">1003</span>
          <small class="heading-ray-id">Ray ID: 4008877c328342f8 &bull; 2018-03-24 10:42:07 UTC</small>
        </h1>
        <h2 class="cf-subheadline" data-translate="error_desc">Direct IP access not allowed</h2>
      </div><!-- /.header -->
      <section></section><!-- spacer -->
      <div class="cf-section cf-wrapper">
        <div class="cf-columns two">
          <div class="cf-column">
            <h2 data-translate="what_happened">What happened?</h2>
            <p>You've requested an IP address that is part of the <a data-orig-proto="https" data-orig-ref="www.cloudflare.com/5xx-error-landing?utm_source=error_100x" target="_blank">Cloudflare</a> network. A valid Host header must be supplied to reach the desired website.</p>
          </div>
            <h2 data-translate="what_can_i_do">What can I do?</h2>
            <p>If you are interested in learning more about Cloudflare, please <a data-orig-proto="https" data-orig-ref="www.cloudflare.com/5xx-error-landing?utm_source=error_100x" target="_blank">visit our website</a>.</p>
          </div>
        </div>
+IPD,864:</div><!-- /.section -->
      <div class="cf-error-footer cf-wrapper">
  <p>
    <span class="cf-footer-item">Cloudflare Ray ID: <strong>4008877c328342f8</strong></span>
    <span class="cf-footer-separator">&bull;</span>
    <span class="cf-footer-item"><span data-translate="your_ip">Your IP</span>: ------------</span>
    <span class="cf-footer-item"><span data-translate="performance_security_by">Performance &amp; security by</span> <a data-orig-proto="https" data-orig-ref="www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
  </p>
</div><!-- /.error-footer -->
    </div><!-- /#cf-error-details -->
  </div><!-- /#cf-wrapper -->
  <script type="text/javascript">
  window._cf_translation = {};
</script>
</body>
</html>
Non riesco a capire dove sto sbagliando, grazie a chi mi aiuterà
sembra sia questo
