ESP8266 easier way to store 128 bytes in non-volatile memory than using SPIFFS?
Hi everybody,
Here is an overview about the whole functionality mostly for your curiosity. I know how to code that part:
I want to program a functionality into ESP8266-boards that receives an ESP-NOW-message that contains the MAC-Adress of the sender. I have one ESP8266 as a central unit that shall receive messages from several other ESP8266.
ESP-NOW is based on the receivers MAC-adress. So what I want to program is press a button on the
sender-unit which will make the sender-unit send its own MAC-Adress to the central-unit.
The central-unit shall store this MAC-Adress in a non-volatile memory.
All in all maybe 5 to 6 or maximum 16 mac-adresses.
I know how to code this part.
Now my question is: is there an easier way to store these few bytes than setting up a SPIFFS Filesystem?
The MAC-adresses are only a few bytes. The MAC-Adresses shall remain inside the ESP8266 even if power is shut off. So a really non-volatile memory is needed.
Does anybody know of an easier way?
best regards Stefan
Why do you think SPIFFS is hard?
There is an ESP8266 library for emulating EEPROM.
gfvalvo:
SPIFFS is not really hard. As I only need to store a very small number of bytes setting up all the things for using SPIFFS
is more than my question
does there exist something like
WriteToMemory(&myByteArray, NumberOfBytes);
ReadFromMemory(&myByteArray, NumberOfBytes);
and everything is done.
I will look into the EEPROM emulation
best regards Stefan
