I am using the following code to save and load credentials to and from EEPROM:
void loadCredentials() {
EEPROM.begin(512);
EEPROM.get(0, ssid);
EEPROM.get(0+sizeof(ssid), password);
char ok[2+1];
EEPROM.get(0+sizeof(ssid)+sizeof(password), ok);
EEPROM.end();
if (String(ok) != String("OK")) {
ssid[0] = 0;
password[0] = 0;
Serial.println("Recovered credentials:");
Serial.println(ssid);
Serial.println(strlen(password)>0?"********":"<no password>");
/** Store WLAN credentials to EEPROM */
void saveCredentials() {
EEPROM.begin(512);
EEPROM.put(0, ssid);
EEPROM.put(0+sizeof(ssid), password);
char ok[2+1] = "OK";
EEPROM.put(0+sizeof(ssid)+sizeof(password), ok);
EEPROM.commit();
EEPROM.end();
Serial.print("Saving SSID: ");
Serial.print("Password: ");
Serial.println(password);
Serial.println("Done");
However, loadCredentials() always returns empty or invalid credentials. I cannot quite understand why though as saveCredentials() appears to run correctly, and WiFi.begin(ssid, passaord) works without any issues (until you reset)
here is the code used to set the credentials into the variables:
if(ssidchange){
a = String(a);
a.toCharArray(tempssid, 50);
ssid = tempssid;
Serial.print("Done, SSID changed to ");
ssidchange = false;
else if(passchange){
char temppass[50];
String a2 = String(a);
a2.toCharArray(temppass, 50);
ssid = tempssid;
password = temppass;
Serial.print("SSID changed to ");
Serial.println(tempssid);
Serial.print("and pass changed to ");
saveCredentials();
delay(3000);
ESP.restart();
Compilable verison of the code
Thank you very much in advance!
