ESP8266 emits random/garbage chars on external supply (works on arduino 5/3.3v)
Summary: With arduino’s 5v & 3.3v supply , ESP8266 module emits boot messages and responds to AT commands on serial terminal@115200 baud as -
boot message:
<random/garbage characters>
Ai-Thinker Technology Co. Ltd.
ready
“AT” command output:
OK
“AT+GMR” output:
AT version:1.2.0.0(Jul 1 2016 20:04:45)
SDK version:1.5.4.1(39cb9a32)
Dec 2 2016 14:21:16
OK
whereas with external (tried multiple power source - details to follow) 3.3v power supply, there are garbage/random characters in the boot message, and response to AT command also has garbage characters.
Though arduino’s 5v and 3.3v have fixed the issue for me, but it is not recommended to use the those for powering up ESP, as Arduino’s
  • 5v can be dangerous for ESP (got hot within few minutes of connection) and,
  • 3.3v may not have enough current (dangerous for Arduino/Atmega chip),
so now, it seems i need to achieve close to what arduino’s 5v and 3v3 pins are delivering to ESP’s Vcc using external power source.
Details: I had purchased ESP8266 module from amazon, and trying make it to pass some basic tests like running AT command via serial monitor, planning to go to programming part later. Here is what i have tried so far wrt. input power for the ESP module.
Attempt1 (fail):
AC —> 5v/1A output DC adapter —> AMS1117 (3.3v) → ESP8266’s Vcc
As per information in iotbytes article, I fed ~3.3v (measured via voltmeter) to Vcc of ESP8266 from pin#2 of ams1117, and had used all capacitors of values as suggested in the post.
  • (Observation):
    Blue led flashing rapidly, Red LED glowing constantly,
    AI Thinker SSID appears , to which, I am able to connect (192.168.4.2) via my laptop and can ping 192.168.4.1
    Serial monitor gets filled up with garbage values at all baud rates except 115200. At 115200, serial monitor is quiet and i get 2/3 garbage characters in response to AT command.
  • (Pinout):
    Used pin #2(3.3v output) & #3 (Ground) of Ams1117 to power the module. Rest other pin connections is same as an article on medium.com as
		Esp8266 | Arduino
		RX      | RX
		TX      | TX
		GPIO 0  | None
		GPIO 2  | None
		Arduino | Arduino
		Reset   | GND
		Esp8266 | AMS1117
		Vcc   	| 3.3v
		CH_PD 	| 3.3v (/Vcc of esp8266)   tried via jumper as well as 100 Ohm resistor
		GND   	| GND
Afterwards, I tried moving ahead by putting ESP8266 to programming mode by following a video . Had to add only 1 “additional” connection -
          Esp8266 | Arduino
           GPIO0   | GND
And , on uploading esp8266 LED blink program, got (@9600/115200 upload rates) -
Global variables use 27968 bytes (34%) of dynamic memory, leaving 53952 bytes for local variables. Maximum is 81920 bytes.
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
tried adding 1k resistor with GPIO-Ground, but it didn’t work!!
Attempt2 (fail):
9v/1A battery —> Buck Converter (adjusted to 3.3v output) → ESP8266’s Vcc
  • (Observation):
    Blue led flashes once and remains off (till i disconnect & reconnect Vcc), Red LED glowing constantly.
    AI Thinker SSID appears and can connect to/ping it
    Serial Monitor … garbage in response to AT command.
  • (Pinout):
		Esp8266 | Arduino
		(Same as Attempt1)
		Arduino | Arduino
		(Same as Attempt1)
		Esp8266 | Buck Converter
		Vcc   	| 3.3v
		CH_PD 	| 3.3v (/Vcc of esp8266) - tried via jumper as well as 100 Ohm resistor
		GND   	| GND
Attempt3 (fail):
AC —> 5v/1A output DC adapter —> Buck Converter (adjusted to 3.3v output) → ESP8266’s Vcc
  • (Observation): Same as Attempt2
  • (Pinout): Same as Attempt2
Attempt4 (pass):
Arduino (5v and 3v3) —> ESP8266’s Vcc
  • (Observation):
    Blue led flashes once and remains off (till i type in a command via serial Monitor), Red LED glowing constantly.
    Serial monitor captures ESP8266’s boot/welcome message and responds to AT commands @115200 baud.
  • (Pinout):
		Esp8266 | Arduino
		RX      | RX
		TX      | TX
		GPIO 0  | None
		GPIO 2  | None
		Vcc   	| 3.3v (also tried 5v)
		GND   	| GND
		Arduino | Arduino
		Reset   | GND
Note:
  • arduino is being powered using usb (a to b) port of laptop .
  • in Attempt 1-3 ( when ESP is powered externally) ground of external supply & arduino’s ground are disconnected / not common
What could be the reasons behind this behavior of ESP with external power source?. I can post more information if required. Any help / suggestion could be very useful.
