Esp8266 erase all data
hello, i've seen that in arduino ide when i upload to esp e12 i have a lot of setting. should i enable erase all flash content ?
also do i have to use 80 mhz or 160mhz ?
Hi
'erase all flash' is not necessary to upload a new code
Use this option only if you have a good reason to erase all flash memory (for instance remove SSID and password for last 'good' AP)
Use 80 MHz if you want to reduce energy consumption
the modules are new and i intend to use them only for espnow communication that don t require pss and other stuff but i mean if it should erase some setting if there are previously just to make sure
do it if you prefer , no risk !
The next uploading will put on flash all necessary things
(The important first level bootloader stays in ROM , not in Flash, no risk to erase it)
