i want to send data using get from nodemcu to phpmyadmin localhost but as i am uploading the code
error -1shows that is not getting the response payload and one more thing as i am a beginer i want to know which ip address is to be used in the path either 127.0.0.1(ip address of localhost) or ip address of the wifi network we are working on ....btw my code is
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
const char *ssid = "Nodemcu";
const char *password = "yonexcarbonex";
//Web/Server address to read/write from
const char *host = "192.168.43.57";
WiFi.mode(WIFI_OFF); //Prevents reconnection issue (taking too long to connect)
WiFi.mode(WIFI_STA); //This line hides the viewing of ESP as wifi hotspot
WiFi.begin(ssid, password); //Connect to your WiFi router
Serial.println("");
Serial.print("Connecting");
// Wait for connection
Serial.print(".");
//If connection successful show IP address in serial monitor
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
HTTPClient http; //Declare object of class HTTPClient
String ADCData, station, getData, Link;
int adcvalue=analogRead(A0); //Read Analog value of LDR
ADCData = String(adcvalue); //String to interger conversion
station = "B";
Serial.print(ADCData);
//GET Data
getData = "?status=" + ADCData + "&station=" + station ; //Note "?" added at front
Link = "http://192.168.43.57/c4yforum/getdemo.php" + getData;
http.begin(Link);
int httpCode = http.GET();
String payload = http.getString();
Serial.println(httpCode);
Serial.println(payload);
http.end(); //Close connection
delay(5000);
