ESP8266 error while uploading
I'm getting an error while uploading an example program to my ESP-01 module
Here is the code
 *  This sketch demonstrates how to scan WiFi networks.
 *  The API is almost the same as with the WiFi Shield library,
 *  the most obvious difference being the different file you need to include:
#include "ESP8266WiFi.h"
  // Set WiFi to station mode and disconnect from an AP if it was previously connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.println("Setup done");
  Serial.println("scan start");
  // WiFi.scanNetworks will return the number of networks found
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0)
    Serial.println("no networks found");
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
      delay(10);
  Serial.println("");
  // Wait a bit before scanning again
  delay(5000);
The error message is
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
java.io.IOException: jssc.SerialPortException: Port name - COM4; Method name - setEventsMask(); Exception type - Can't set mask.
I choose Tools>>Board>>Generic ESP8266 Module
But when I choose that there are so many options for that board like Flash frequency,Flash mode How should I configure that.
My COM port was COM4
Here is the Hardware setup
