ESP8266 ESP-01 need some help with 1st progrm
I am trying to figure out a few old ESP8266 ESP-01s I have lying around. I have a few very simple projects in mind, using Arduino and Wifi.
But I have trouble uploading the most basic scripts, can someone help point out what I am doing wrong? Or point out if I'm completely misunderstanding how it works.
Here we go.
My setup is ESP8266 connected through a serial connecter (5v) passing through a bi-directional level switch. The ESP8266 is powered by a 3.3v external source, the serial connecter uses USB power. Communication works fine.
I am flashing ESP8266 with the nodemcu-1.5.4.1 version.
Successfully.
~/esptool$ python3 esptool.py --port /dev/ttyUSB0 write_flash -fm qio 0x00000 nodemcu-1.5.4.1-final-7-modules-2023-03-24-02-15-55-float.bin
esptool.py v4.6-dev
Serial port /dev/ttyUSB0
Connecting...................
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting...
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 5c:cf:7f:fd:cc:9d
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00062fff...
Compressed 404580 bytes to 258713...
Wrote 404580 bytes (258713 compressed) at 0x00000000 in 23.2 seconds (effective 139.8 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Checking the firmware version with ESPlorer. Looks good. I can even run basic commands and send LUA scripts.
NodeMCU custom build by frightanic.com
	branch: 1.5.4.1-final
	commit: 9ad37255717e02120f43f213a892a845dbe40615
	SSL: false
	modules: file,gpio,net,node,tmr,uart,wifi
 build created on 2023-03-24 02:15
 powered by Lua 5.1.4 on SDK 1.5.4.1(39cb9a32)
lua: cannot open init.lua
But I want to integrate it in an Arduino project, so I want to use Arduino IDE to program it.
So I start with the simplest script:
  Serial.begin(115200); // initialize serial communication
  Serial.println("Hello, world!"); // print "Hello, world!" to the serial port
  delay(1000); // wait for 1 second
And upload it with Arduino IDE:
. Variables and constants in RAM (global, static), used 28108 / 80192 bytes (35%)
║   SEGMENT  BYTES    DESCRIPTION
╠══ DATA     1496     initialized variables
╠══ RODATA   940      constants
╚══ BSS      25672    zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 59747 / 65536 bytes (91%)
╠══ ICACHE   32768    reserved space for flash instruction cache
╚══ IRAM     26979    code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 236132 / 1048576 bytes (22%)
╚══ IROM     236132   code in flash
esptool.py v3.0
Connecting........_
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Auto-detected Flash size: 1MB
Compressed 269696 bytes to 198407...
Writing at 0x00000000... (7 %)
Writing at 0x00004000... (15 %)
Writing at 0x00008000... (23 %)
Writing at 0x0000c000... (30 %)
Writing at 0x00010000... (38 %)
Writing at 0x00014000... (46 %)
Writing at 0x00018000... (53 %)
Writing at 0x0001c000... (61 %)
Writing at 0x00020000... (69 %)
Writing at 0x00024000... (76 %)
Writing at 0x00028000... (84 %)
Writing at 0x0002c000... (92 %)
Writing at 0x00030000... (100 %)
Wrote 269696 bytes (198407 compressed) at 0x00000000 in 17.6 seconds (effective 122.3 kbit/s)...
ESPLorer result:
Communication with MCU...
Got answer! Communication with MCU established.
AutoDetect firmware...
Can't autodetect firmware, because proper answer not received (may be unknown firmware).
Please, reset module or continue.
<Somegibberish>
Hello, world!
Hello, world!
Hello, world!
The script works, but my firmware is gone.
Any idea what is going on?
Am I misunderstanding how this should work, and should stick to LUA scripts instead?
This is what my Arduino board looks like:
