I'm doing a project and I'm using a arduino uno, ESP8266 ESP-01 wifi and a PostgreSQL database.
I want that arduino sends a message to the wifi sensor and the wifi sensor needs to insert the data received in the database.
Once I'm a beginner with this sensor I followed a tutorial Tutorial page and the differences are that in the tutorial they are using the firebase and other sensors (Distance measuring sensor, Ultrasonic Distance Sensor) and I'm just using the PostgreSQL database.
1º I upload de code to the wifi sensor and I made the connection as shown in the tutorial;
2º I upload de code to the arduino;
My arduino code is a little different, because I was just doing a test to see if the arduino was sending the data to the wifi sensor.
But that is not happening. The arduino write the data in the monitor, but the wifi sensor is not answering.
I don't know why and how I can solve it.
Is someone there who can help me, please?
My code:
Arduino:
//Initializes the serial connection at 9600 to sent sensor data to ESP8266.
while (Serial.available()) {
Serial.print("TEST");
delay(2000);
Wifi sensor:
#include <ESP8266WiFi.h>
#define WIFI_SSID "******"
#define WIFI_PASSWORD "******"
String sensor_data;
//Initializes the serial connection at 9600 get sensor data from arduino.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
//get sensor data from serial put in sensor_data
sensor_data = Serial.readString();
Serial.println("WIFI ANWSER: " + sensor_data);
Hi, your code and connections are correct, however, esp is bad for logging into serial monitor. You can try logging by sending a request to your server and debug the log there. I will put my working example here:
ESP Code:
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <SoftwareSerial.h>
String ssid = "ssid";
String password = "pass";
// Server URL and endpoint
// See this utility that provides a mock server where you can see the requests https://webhook.site/
String serverURL = "http://webhook.site";
String endpoint = "/your-webhook-path";
String fullLink = serverURL + endpoint;
WiFiClient wifiClient;
void setupWifi() {
WiFi.begin(ssid, password);
void doRequest(String url) {
if (WiFi.status() == WL_CONNECTED) {
// Create an HTTPClient object
HTTPClient http;
http.setTimeout(10000);
// Make a GET request to the server
http.begin(wifiClient, url);
int httpResponseCode = http.GET();
if (httpResponseCode > 0) {
String response = http.getString();
// Close the connection
http.end();
setupWifi();
doRequest(fullLink + String("?msg=SET+UP+ESP01"));
String sensor_data = Serial.readString();
doRequest(fullLink + String("?msg=WIFI+ANWSER:+") + sensor_data);
