Hello Dear Reader,
New to Arduino/ESP8266, but some minor mechatronics coding back in school, so heavy on the mechanics, weak on networking syntax. I've done lots of homework on this, and have semi functioning code, but II can't seem to identify the syntax or timing (state?) issue in my code.
I have two ESP8266 boards (one master one slave), and I'm trying to create an esp-now exchange between two sensors on a part of my farm that doesn't have wifi or power.
To simulate the door states, I have two buttons, Green Button for Small Door, Red Button for the large door. Eventually these will be magnetic reed switches.
On the transmitter side with the buttons, I am getting correct real-time status updates to the serial monitor, as well as a successful notification that packets were received.
On the receiver side, I am getting a successful esp-now pairing with the transmitter, able to read the incoming MAC address, the size of the packet, and print those two items to the serial monitor.
However the bool values for the states of the two garage doors, are just reading consistent "0"/false/low.
Is this a syntax issue of how I am pushing the values to serial print here
Serial.println(myData.largeDoorState);
Serial.println(myData.smallDoorState);
or perhaps how the data is being decoded here:
void OnDataRecv(uint8_t * mac_addr, uint8_t *incomingData, uint8_t len) {
char macStr[18];
Serial.print("Packet received from: ");
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.println(macStr);
memcpy(&myData, incomingData, sizeof(myData));
Credit to the syntax found on random nerd tutorials for the inspiration
ESP-NOW: Receive Data from Multiple ESP8266 Boards (many-to-one) | Random Nerd Tutorials)
Full code for the Door/Sensor+ Transmitter as well as the receiver code
Door Sensor and Transmitter code
#include <ESP8266WiFi.h>
#include <espnow.h>
// REPLACE WITH RECEIVER MAC Address
uint8_t broadcastAddress[] = {0x40, 0x91,0x51, 0x4F, 0x0F, 0xE8};
byte red_button = D3;
byte green_button = D2;
bool largeDoorState;
bool smallDoorState;
bool prevREDstate = LOW;
bool prevGREENstate = LOW;
bool currentGREENstate = HIGH;
bool currentREDstate = HIGH;
unsigned long lastTime = 0;
unsigned long timerDelay = 3000;
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
} struct_message;
struct_message myData;// Create a struct_message called test to store variables to be sent
// Callback when data is sent
void OnDataSent(uint8_t *mac_addr, uint8_t sendStatus) {
Serial.print("\r\nLast Packet Send Status: ");
if (sendStatus == 0){
Serial.println("Delivery success");
else{
Serial.println("Delivery fail");
WiFi.mode(WIFI_STA);
WiFi.disconnect();
Serial.begin(115200); Serial.println();
Serial.println("Serial Communication Initalized");
pinMode(red_button,INPUT_PULLUP);
pinMode(green_button,INPUT_PULLUP);
// Init ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Error initializing ESP-NOW");
return;
// Set ESP-NOW role
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
// Once ESPNow is successfully init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
esp_now_add_peer(broadcastAddress, ESP_NOW_ROLE_SLAVE, 1, NULL, 0);
void checkRedDoor () {
int currentREDstate = digitalRead(red_button);
if(prevREDstate != currentREDstate){
if(currentREDstate == LOW){
largeDoorState = false;
Serial.println("The Large Garage Door is Closed");
else if(currentREDstate == HIGH){
largeDoorState = true;
Serial.println("The Large Garage Door is Open");}
prevREDstate = currentREDstate;
void checkGreenDoor () {
int currentGREENstate = digitalRead(green_button);
if(prevGREENstate != currentGREENstate){
if(currentGREENstate == LOW){
smallDoorState = false;
Serial.println("The Small Garage Door is Closed");
else if(currentGREENstate == HIGH){
smallDoorState = true;
Serial.println("The Small Garage Door is Open");}
prevGREENstate = currentGREENstate;
checkRedDoor ();
checkGreenDoor();
if ((millis() - lastTime) > timerDelay) {
// Set values to send
myData.smallDoorState;
myData.largeDoorState;
// Send message via ESP-NOW
esp_now_send(0, (uint8_t *) &myData, sizeof(myData));
lastTime = millis();
Receiver/Monitor Code
#include <espnow.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
byte red_LED = D3;
byte green_LED = D2;
} struct_message;
char macStr[18];
Serial.printf("Recieved:%u bytes\n", len);
pinMode(red_LED,OUTPUT);
pinMode(green_LED,OUTPUT);
// Set device as a Wi-Fi Station
WiFi.disconnect();
// Init ESP-NOW
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
//esp_now_register_recv_cb(OnDataRecv);
