I just want to know the reason for the following exception so I can find what is causing it.
The project was on hold for a month or so and when I left it I checked in the code and the last flash binary to SVN.
Now when I restarted work it turns out that if I load the head flash image from SVN into the hardware (ESP-07) it constantly reboots after running the setup code with a number of debug port messages I have put there.
But towards the end of setup() it runs into an exception and it is not at a constant place.
The execution reaches different points before rebooting...
I have cut out the first piece of debug code from the ESP:
This always happens when the exception is triggered. What exactly does the "LoadProhibitedCause" mean?
The code uses 3 tcp services and stores config data in EEPROM and SPIFFS.
Any ideas?
BTW: If is retrieve the flash binary from earlier revisions in SVN there are no exceptions, so I must have been doing something really bad the last time I worked on it...
Thanks!
The first document is a debugging guide and I guess I have a different case than the examples there...
The second document had this on the exception itself:
28 LoadProhibitedCause A load referenced a page mapped with an attribute that does not permit loads Region Protection or MMU Yes
What I don't understand here is what the page and its attribute are....
Any suggestions? Does it pertain to SPIFFS pages or EEPROM pages or what? I use both, but I think SPIFFS was not enabled in the binaries I have saved before the last one.
And there I don't get exceptions.
I can't really help on the further interpretation of the error message, but page in this context will be a unit of memory. I could imagine something related to loading a cached page into ram, but that is just a guess.
I think you simply have to revert to a working version of your sketch and add code until it breaks. Issues to watch for which cause mysterious crashes include allowing code, which should remain in RAM (ISRs / callbacks etc.), to be cached.
Yes, I have to master how to compare SVN repo revisions against the working copy.
I am on command line in Windows for SVN... In CVS, which we used before, there was a WinCVS program that helped with that. But I digress...
There are only so much in between the working binary revision and the head.
I was busy trying to calculate a correct value to run deep sleep with in order for it to wake up exactly on time when I left the project before. So when committing I did not include the flash binary to save space, and therefore I don't know what actually broke the sketch. But probably the diff between the head and previous revisions.
It sounds like development methodology could also be a factor here. Everyone has their own way of developing a sketch. I now use Sloeber (Eclipse) but I started this method with the Arduino IDE.
Create a sketch and name it with a suffix v0.01. In the sketch folder are also all modified library files etc.
After modifications and testing, simply save the whole thing (save_as option in the IDE, a cut and paste operation is Sloeber) , incrementing the version number and maintaining a version history in the sketch. I don't expose myself to complexities of external source management systems and the like and have always something I can go back to.
Of course, that does not preclude a library update or similar rendering the whole thing unusable, but that is another issue.
