ESP8266 Fatal Expection Error
Hi im new to arduino coding. Im using a nodemcu esp8266 board and i want to make a project with it. I write a code it works but i t gives an error while working. I need help pls.
There is my code:
#include <ESP8266WiFi.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <SPI.h>
#include <SD.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
const char* ssid = "Karabiberim"; // Wi-Fi ağınızın adı
const char* password = "XXXXXXXXXXXX"; // Wi-Fi şifreniz
const int chipSelect = D8;  // CS pin for the SD card
// GPS modülünün bağlı olduğu pinler
const int rxPin = D3; // GPS TX pini
const int txPin = D4; // GPS RX pini
const char *mqtt_broker = "broker.emqx.io"; // Enter your WiFi or Ethernet IP
const char *topic = "XXXXXXXXXXXX";
const int mqtt_port = 1883;
WiFiClient espClient;
PubSubClient client(espClient);
// GPS verilerini saklamak için TinyGPS++ nesnesi oluşturuluyor
TinyGPSPlus gps;
Adafruit_BMP085 bmp;
Adafruit_MPU6050 mpu;
Adafruit_Sensor *mpu_temp, *mpu_accel, *mpu_gyro;
unsigned long previousMillis = 0;
const long interval = 1000;  // 1 saniye (1000 milisaniye)
  String latitude = "*****";
  String longitude = "*****";
  String altitude = "*****";
  String satallites = "*****";
  String accx = "*";
  String accy = "*";
  String accz = "*" ;
  String gyrox = "*";
  String gyroy = "*";
  String gyroz = "*";
  String mputemp = "*";
  String pressure = "**";
  String bmptemp = "**";
  String freeheap = "**";
// SoftwareSerial nesnesi oluşturuluyor
SoftwareSerial gpsSerial(rxPin, txPin);
  Serial.begin(9600); // Seri haberleşme başlatılıyor
  delay(200);
  gpsSerial.begin(9600); // GPS ile haberleşme başlatılıyor
  client.setServer(mqtt_broker, mqtt_port);
  client.setCallback(callback);
  if (!bmp.begin()) {
    Serial.println("BMP180 sensörü bulunamadı, lütfen bağlantıları kontrol edin!");
    yield();
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    yield();
  smartDelay(10);
  if (!SD.begin(chipSelect)) {
    Serial.println("SD card initialization failed!");
    yield();
    return;
  Serial.println("SD card initialized.");
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  mpu.setGyroRange(MPU6050_RANGE_500_DEG);
  mpu.setFilterBandwidth(MPU6050_BAND_5_HZ);
  yield();
  connectWifi();
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  // GPS verilerini oku
  if (gpsSerial.available() > 0 && WiFi.status() == WL_CONNECTED){
    gps.encode(gpsSerial.read());
      // GPS verisi geçerli ise
      if (gps.location.isValid()) {
        Serial.print("Enlem: ");
        Serial.println(gps.location.lat(), 6); // 6 hane hassasiyet
        latitude = String(gps.location.lat(),6);
        Serial.print("Boylam: ");
        Serial.println(gps.location.lng(), 6); // 6 hane hassasiyet
        longitude = String(gps.location.lng(),6);
        //Serial.print("Yükseklik: ");
        //Serial.println(gps.altitude.meters());
        //altitude = String(gps.altitude.meters());
        //Serial.print("Uydusayısı: ");
        //Serial.println(gps.satellites.value());
        //satallites = String(gps.satellites.value());
      else {
        // GPS verisi geçersiz ise
        Serial.println("Geçersiz GPS verisi!");
  if (mpu.begin()) {
  Serial.print("Acceleration X: ");
  Serial.print(a.acceleration.x);
  accx = String(a.acceleration.x);
  Serial.print(", Y: ");
  Serial.print(a.acceleration.y);
  accy = String(a.acceleration.y);
  Serial.print(", Z: ");
  Serial.print(a.acceleration.z);
  accz = String(a.acceleration.z);
  Serial.println(" m/s^2");
  Serial.print("Rotation X: ");
  Serial.print(g.gyro.x);
  gyrox = String(g.gyro.x);
  Serial.print(g.gyro.y);
  gyroy = String(g.gyro.y);
  Serial.print(g.gyro.z);
  gyroz = String(g.gyro.z);
  Serial.println(" rad/s");
  Serial.print("Temperature: ");
  Serial.print(temp.temperature);
  mputemp = String(temp.temperature);
  Serial.println(" degC");
  else{
    Serial.println("MPU bulunamadı.");
  if (bmp.begin()) {
  Serial.print("Sıcaklık: ");
  Serial.println(bmp.readTemperature());
  bmptemp = String(bmp.readTemperature());
  Serial.print("Free Heap: ");
  Serial.println(ESP.getFreeHeap());
  freeheap = String(ESP.getFreeHeap());
  Serial.print("basınc: ");
  Serial.println(bmp.readPressure());
  pressure = String(bmp.readPressure());
  else{
    Serial.println("BMP bulunamadı.");
  StaticJsonDocument<200> doc; // JSON belge boyutu
  doc["accx"] = accx;
  doc["accy"] = accy;
  doc["accz"] = accz;
  doc["gyrox"] = gyrox;
  doc["gyroy"] = gyroy;
  doc["gyroz"] = gyroz;
  doc["mputemp"] = mputemp;
  doc["pressure"] = pressure;
  doc["bmptemp"] = bmptemp;
  doc["freeheap"] = freeheap;
  String jsonString;
  serializeJson(doc, jsonString);
StaticJsonDocument<00> doc2;
  doc2["latitude"] = latitude;
  doc2["longitude"] = longitude;
  //doc2["altitude"] = altitude;
  //doc2["satallites"] = satallites;
  String jsongpsString;
  serializeJson(doc2, jsongpsString);
  smartDelay(10);
  writeFile("json.txt", jsonString.c_str());
  smartDelay(10);
  writeFile("jsongps.txt", jsongpsString.c_str());
  smartDelay(20);
  client.connect("admin");
  client.loop();
  client.publish(topic, jsonString.c_str());
  client.publish(topic, jsongpsString.c_str());
  //client.disconnect();
  //WiFi.disconnect();
  smartDelay(300);
  // Diğer işlemleri buraya ekleyin, GPS verileri işlenirken döngü devam eder
void smartDelay(unsigned long ms) {
  unsigned long start = millis();  // Başlangıç zamanını al
  do {
    // Bekleme süresi kadar zaman geçene kadar diğer işlemleri yap
    while (gpsSerial.available() > 0) {
  } while (millis() - start < ms);
void writeFile(const char* filename, const char* message) {
  File file = SD.open(filename, FILE_WRITE);
  if (file) {
    file.println(message);
    file.close();
    Serial.println("Write to SD card successful.");
    Serial.println("Error opening file for writing.");
void connectWifi(){
  yield();
  if (WiFi.status() != WL_CONNECTED) {
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("Wi-Fi'ye bağlanıldı");
  Serial.println("IP Adresi: " + WiFi.localIP().toString());
void callback(char *topic1, byte *payload, unsigned int length) {
 Serial.print("Message arrived in topic: ");
 Serial.println(topic1);
 Serial.print("Message:");
 String s;
 for (int i = 0; i < length; i++) {
  Serial.print((char) payload[i]);
  s += (char)payload[i];
And this is the error:
15:26:50.800 -> SDK:2.2.2-dev(38a443e)/Core:3.1.0=30100000/lwIP:STABLE-2_1_3_RELEASE/glue:1.2-65-g06164fb/BearSSL:b024386
15:26:51.698 -> SD card initialized.
15:26:51.698 -> Fatal exception 0(IllegalInstructionCause):
15:26:51.783 -> epc1=0x40210728, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
15:26:51.850 ->
15:26:51.850 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
15:26:51.916 ->
15:26:51.916 -> Exception (0):
15:26:51.949 -> epc1=0x40210728 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
15:26:52.050 ->
15:26:52.050 -> >>>stack>>>
15:26:52.050 ->
15:26:52.050 -> ctx: cont
15:26:52.050 -> sp: 3ffff5c0 end: 3ffffd20 offset: 0190
15:26:52.116 -> 3ffff750:  feefeffe feefeffe feefeffe feefeffe
15:26:52.149 -> 3ffff760:  feefeffe feefeffe feefeffe feefeffe
15:26:52.216 -> 3ffff770:  feefeffe feefeffe 00000001 feefeffe
15:26:52.249 -> 3ffff780:  feefeffe feefeffe feefeffe c0038035
15:26:52.316 -> 3ffff790:  00000000 00000001 00000000 40100bbc
15:26:52.383 -> 3ffff7a0:  00000020 feefeffe feefeffe feefeffe
15:26:52.416 -> 3ffff7b0:  feefeffe feefeffe feefeffe 00000022
15:26:52.483 -> 3ffff7c0:  3fffc200 40100af8 3fffc258 4000050c
15:26:52.516 -> 3ffff7d0:  40004378 00000030 0000001c ffffffff
15:26:52.582 -> 3ffff7e0:  60000200 00000008 09051a17 80000000
15:26:52.616 -> 3ffff7f0:  20000000 3ffefe98 80000000 203fc040
15:26:52.682 -> 3ffff800:  80000000 3fffc6fc 00000001 3ffefe9c
15:26:52.715 -> 3ffff810:  00000234 003fc040 00000045 00000030
15:26:52.783 -> 3ffff820:  feefeffe feefeffe feefeffe feefeffe
15:26:52.849 -> 3ffff830:  feefeffe feefeffe feefeffe feefeffe
15:26:52.883 -> 3ffff840:  feefeffe feefeffe feefeffe feefeffe
15:26:52.947 -> 3ffff850:  feefeffe feefeffe feefeffe feefeffe
Ok.
Well if you are new to it, you didn't write that code.
You mean it compiles i guess.
But the ESP crashes !.
There are many possible causes for this.
First of all where did you get the code from ?
2nd, swSerial on an ESP is not such a reliable method and tends to cause issues.
For the rest, i have no idea, but try and run the exception decoder, maybe that will point you in a direction where you find solutions.
I write the code. The swSerial works well i test and the baudrates and 9600 works best for me. Thanks.
