Nach dem Einfügen der Boardverwalter URL für das ESP8266-Modul habe ich im Boardverwalter folgenden Fehler.
und in der Infobox stehen diese Fehler:
Invalid UTF-32 character 0x12390400(above 10ffff) at char #1552, byte #6211)
java.lang.RuntimeException: java.io.CharConversionException: Invalid UTF-32 character 0x12390400(above 10ffff) at char #1552, byte #6211)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$0(ContributionManagerUI.java:151)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.CharConversionException: Invalid UTF-32 character 0x12390400(above 10ffff) at char #1552, byte #6211)
at com.fasterxml.jackson.core.io.UTF32Reader.reportInvalid(UTF32Reader.java:189)
at com.fasterxml.jackson.core.io.UTF32Reader.read(UTF32Reader.java:150)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.loadMore(ReaderBasedJsonParser.java:153)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._skipWSOrEnd(ReaderBasedJsonParser.java:2017)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:577)
at com.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:3776)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3721)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:2796)
at cc.arduino.contributions.packages.ContributionsIndexer.parseIndex(ContributionsIndexer.java:180)
at cc.arduino.contributions.packages.ContributionsIndexer.parseIndex(ContributionsIndexer.java:93)
at processing.app.BaseNoGui.initPackages(BaseNoGui.java:602)
at processing.app.Base$9.onIndexesUpdated(Base.java:1309)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$0(ContributionManagerUI.java:149)
... 1 more
at processing.app.Base.openBoardsManager(Base.java:1327)
at processing.app.Base$10.actionPerformed(Base.java:1350)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.Component.processMouseEvent(Component.java:6533)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6298)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
