ESP8266 GET from web using AT commands
I am using the ESP8266, currently connected to my computer serial port through an Arduino UNO. The Arduino sends my commands (which I enter in the COM port) to the module via softwareSerial, and returns the ESP's responses to the Arduino COM port. Simple enough. Running at 9600 baud, I am trying to post some sensor data to an online api. I used thingspeak, and the whole setup worked perfectly. My data was updated in the cloud and I saw it instantaneously.
However, when I tried using the same on another api on my own domain, it just refuses to work.
AT+CIPSTART="TCP","www.*****.com",80
AT+CIPSEND=15
GET /test.php
The above sequence of commands returns a full html page with "Error 404 File Not Found", as follows:
+IPD,1460:
File Not Found I tried POST and GET, and several variations. Some return a "bad request" error page. Any ideas as to where the issue could be? I'm completely stumped. Could it be a server side issue? Or am I doing something wrong in the AT commands? Any pointers would be greatly appreciated. Thanks!
Solved.
:slight_smile:
The server was expecting more headers along with the GET request.
GET /test.php HTTP/1.0
Host: www.******.com
This is what finally worked.
i am having the same problem. and having the error such as
+IPD,212:HTTP/1.0 408 Request Time-out
Cache-Control: no-cache
Connection: close
Content-Type: text/html
Your browser didn't send a complete request in time. CLOSED
