ESP8266 Getting Data From Webpage Input Box
I need help about getting data from webpage. I set ESP8266 as AP and I set a webpage which has two input box and a button. User should write network ID and password to these input boxes and i need to get these ID and password then set ESP8266 as STA. I searched a lot and I find substring() to get data from these boxes. I don't know if I did it right but I get datas but not exactly right! If user writes abcenser to ID I get it as abconser or something like that i mean i can't get data right. Password is like that too sometimes it takes all characters but one or two charecters are wrong sometimes can't get all characters just a part of it.. It changes everytime i don't know what should i do so i really need help.. If there is any way other than using substring() that's okay too
The code I use
#include "String.h"
#include "uartWIFI.h"
#define SSID "esp_mod_01"
#define PASSWORD "esp_sifre_01"
String ssid;
String pass;
String readString;
String Getdata;
WIFI wifi;
extern int chlID;
int webtype;
void setup(){
  wifi.begin(); //AT+RST ile modul kontrolü
  DebugSerial.println("AP modu aciliyor");
  setupAP();
void setupAP(){
  bool b = wifi.Initialize(AP, SSID, PASSWORD, 3 ,0);
  if(!b){
      DebugSerial.println("Init error");
  else{
    DebugSerial.println("Init OK!");
  delay(3000);
  String ipstring  = wifi.showIP();
  DebugSerial.println(ipstring);
  wifi.confMux(1);
  bool c = wifi.confServer(1,80);
  if(!c){
    DebugSerial.println("SERVER error!");
  else{
    DebugSerial.println("SERVER OK!");
    webtype = 1;
   if (webtype == 1){
      setupAPmode();
void setupAPmode(){
     if(_cell.find("+IPD")){
        String cmd;
        cmd = "HTTP/1.1 200 OK\r\n";
        cmd += "Content-Type: text/html\r\n";
        cmd += "Connection: close\r\n";
        cmd += "\r\n";
        cmd += "<!DOCTYPE HTML>\r\n";
        cmd += "<html>\r\n";
        cmd += "<form method=get>";
        cmd += "<label>SSID</label>
        cmd += "<input  type='text' name='ssid' maxlength='30' size='15'>
        cmd += "<label>Password</label>
        cmd += "<input  type='password' name='password' maxlength='30' size='15'>
        cmd += "<input  type='submit' value='connect' >";
        cmd += "</form>";
        wifi.Send(chlID,cmd);
        wifi.closeMux(chlID);
        if(_cell.available()){
              Getdata = _cell.readString();
              int _referans = Getdata.indexOf("ssid");
              int _ssid_num = Getdata.indexOf('=',_referans+1);
              int _belirleyici = Getdata.indexOf('&');
              int _pass_num = Getdata.indexOf('=',_belirleyici+1);
              int _belirleyici2= Getdata.indexOf(' ',_pass_num+1);
              String _ssid = Getdata.substring(_ssid_num+1,_belirleyici);
              Serial.print("ssid = ");
              Serial.println(_ssid);
              String _pass = Getdata.substring(_pass_num+1, _belirleyici2);
              Serial.print("pass = ");
              Serial.println(_pass);
              if(_ssid.length()>5 && _pass.length()>5)
                webtype=0;
