ESP8266 hall effect flow meter
I have a project that needs to use at least 2 hall effect flow meters. How many hall effect flow meters can the esp8266 handle at 1 time?
only 1 sensor will be used at a time. is there any reason my modified sample code wont work right? i attach interrupt to SENSOR2 and tell it to use the same pulse counting function.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ESP8266WiFi.h>
#define SCREEN_WIDTH 128    // OLED display width, in pixels
#define SCREEN_HEIGHT 64    // OLED display height, in pixels
#define OLED_RESET -1       // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define LED_BUILTIN 16
#define SENSOR  2
#define SENSOR2  15
long currentMillis = 0;
long previousMillis = 0;
int interval = 1000;
boolean ledState = LOW;
float calibrationFactor = 4.5;
volatile byte pulseCount;
byte pulse1Sec = 0;
float flowRate;
unsigned long flowMilliLitres;
unsigned int totalMilliLitres;
float flowLitres;
float totalLitres;
void IRAM_ATTR pulseCounter()
  pulseCount++;
WiFiClient client;
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
  display.clearDisplay();
  delay(10);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(SENSOR, INPUT_PULLUP);
  pulseCount = 0;
  flowRate = 0.0;
  flowMilliLitres = 0;
  totalMilliLitres = 0;
  previousMillis = 0;
  attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, FALLING);
  attachInterrupt(digitalPinToInterrupt(SENSOR2), pulseCounter, FALLING);
  currentMillis = millis();
  if (currentMillis - previousMillis > interval)
    pulse1Sec = pulseCount;
    pulseCount = 0;
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
    previousMillis = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate / 60) * 1000;
    flowLitres = (flowRate / 60);
    // Add the millilitres passed in this second to the cumulative total
    totalMilliLitres += flowMilliLitres;
    totalLitres += flowLitres;
    // Print the flow rate for this second in litres / minute
    Serial.print("Flow rate: ");
    Serial.print(float(flowRate));  // Print the integer part of the variable
    Serial.print("L/min");
    Serial.print("\t");       // Print tab space
    display.setCursor(10, 0); //oled display
    display.setTextSize(1);
    display.setTextColor(WHITE);
    display.print("Water Flow Meter");
    display.setCursor(0, 20); //oled display
    display.setTextSize(2);
    display.print("R:");
    display.print(float(flowRate));
    display.setCursor(100, 28); //oled display
    display.print("L/M");
    // Print the cumulative total of litres flowed since starting
    Serial.print("Output Liquid Quantity: ");
    Serial.print(totalMilliLitres);
    Serial.print("mL / ");
    Serial.print(totalLitres);
    Serial.println("L");
    display.setCursor(0, 45); //oled display
    display.print("V:");
    display.print(totalLitres);
    display.setCursor(100, 53); //oled display
    display.print("L");
    display.display();
It may not be what your problem is about, but there seems to be an awful lot of text that does not need to be printed every second. So much so that I can't find any of the normally used detach interrupt code.
Try this to help you walk before you try to run
There are plenty of other examples around, and they are all much the same.
