ESP8266 http call after wifi begin
Hi, my esp8266 is set to WIFI_AP_STA and one endpoint is available on server side (ESP is listening to some /FOO)
When I call FOO from my smartphone, passing SSID and PSW, I want my ESP to connect to wifi and then register calling a HTTP client
this is ethe code
WiFi.begin(ssid, pass);
long loopCount = 0;
long loopMaxCount = 10;
while (WiFi.status() != WL_CONNECTED && ++loopCount <= loopMaxCount) {
wl_status_t status = WiFi.status();
debugLog(“connectToWiFIAndRegister”, String(loopCount) + "of " + String(loopMaxCount) +
“: WiFi status: " + String(status) + " (” + WiFiStatusToString(status) + “)”);
if (WiFi.status() != WL_CONNECTED)
return “ERROR”; // TODO returns the right error (like SSID not found)
registerDevice()
The registerDevice function cals some http url passing data and wating for 200 response
The problem is that the registerDevice always throw exception
But connect ESP to WIFI on setup , then registerDevice works fine
Can you help me?
You did not post ALL of your code, or ANY of the details of the exception.
Can you help me?
What do you think?
Here it is
server.on("/connectandcheck", handleConnectAndCheck);
void handleConnectAndCheck()
long loopCount = 0;
long loopMaxCount = 25;
while (++loopCount <= loopMaxCount) {
if (WiFi.status() == WL_CONNECTED)
WiFi.disconnect(); // to erase all WiFi info
server.send(500, “text/plain”, WiFi.status());
return;
WiFiClient client;
if (client.connect(host, 80))
client.print(String(“GET /”) + " HTTP/1.1\r\n" +
"Host: " + host + “\r\n” +
“Connection: close\r\n” +
“\r\n”
String ret = “”;
while (client.connected() || client.available())
if (client.available())
String line = client.readStringUntil(’\n’);
ret += line;
client.stop();
server.send(200, “text/plain”, “OK”);
debugSerialPrintln(“handleConnectAndCheck”, “connection failed!”);
client.stop();
server.send(500, “text/plain”, “TESTHOST ERROR”);
this call, using any client like POSTMAN for example, often returns ERROR
The problem seems to be related to the changes of channel on ESP
  1. ESP starts in AP on channel 1...
  2. client connects to ESP AP
  3. ESP start connecting and changes the channel to 2, 3, ... and immediately the client disconnects from
so the ERROR is probably due to the fact that the client disconnect from ESP
Is there any way to avoid this?
thanks
station and AP of the esp8266 must be on the same chanel. so if you connect as station to some AP, the SoftAP of the esp8266 resets and the browser disconnects. why do you connect to AP in HTTP request handler?
Thank you for reply
My goal is to create a sort of SYNCRONOUS method of ConectAndRegister
This method should return to the client with message OK or KO
any way to do that? from WIFI Connection to HTTP call?
mattdev:
Thank you for reply
it is not possible
Juraj:
it is not possible
ok thanks so what's the best practice for that?
I mean.... I need to do the MOST COMMON use case of the IoT (I mean, fron user prospective)
  • Open APP
  • connect Smarthone to ESP AP
  • send SSID & PSW to ESP
waiting for response like
  • SSID NOT FOUND
or, if the above is passed
  • PASSWORD WRONG
  • NO internet connection
OK, registered!
what0s the right approach to do that?
thanks for helping
mattdev:
  • Open APP
  • SSID NOT FOUND
  • PASSWORD WRONG
OK, registered!
thanks for helping
see WiFiManager library or WiFiLink firmware's WebServer
Juraj:
Hi, thanks for the link
I'm tryng to figure out what's the right CLIENT/SERVER process
As far as I undestand, the ide could be
  1. ESP starts in AP
  2. CLIENT connects to ESP
  3. CLIENT call ESP enpoint http://192.168.1.1/connect?SSID=...
  4. ESP returns immediately 200/OK
  5. then the CLIENT start looping http://192.168.1.1/isConnected untilthe ESP returns something (OK or ERROR)
is my assumption correct?
Is yes, In this case it won't work, as after point #4, the CLIENT automatically disconnects from ESP (due to the channel change), so the calls at poin #5 will always fail
What's your opinion?
thanks for your help
mattdev:
  1. ESP starts in AP
it will not fail. it will reconnect for new request
Juraj:
Hi, not exaclty on smartphones
based on my multiple experiments:
  1. ESP starts in AP
--> ESP starts connection process and change channel
HERE; the smartphone disconnects from ESP and does not reconnects... most of the time smartphone reconnects to HOME WIFI
  1. then the CLIENT start looping http://192.168.1.1/isConnected untilthe ESP returns something (OK or ERROR)
--> the CALL fails because the smarthpone is connected to HOME WIFI, it is not connected to ESP anymore
Am I missing anything?
Are you facing/expecting a diferent behaviour?
Thanks
mattdev:
  1. ESP starts in AP
Thanks
I didn't use it on phone.
try the WiFiManager library
