ESP8266 HTTP FORM-to switch on LED after given input time
We are fairly new to Arduino. We tried to make a HTML form where user can input values and this value can be used by the ESP8266 to switch on the LED after the seconds input by the user. We managed to make the form, but the LED would not switch on after the given time. Here is our code. Can someone please help us figure out the mistakes we are making? Thank you!
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
MDNSResponder mdns;
// Replace with your network credentials
const char* ssid = "xxxxxxx";
const char* password = "xxxxxxx";
ESP8266WebServer server(80);
String webPage = "";
int gpio5_pin = 5;
void setup(void){
  webPage += "HTTP/1.1 200 OK";
  webPage += "Content-Type: text/html";
  webPage += "";
  webPage += "<HTML>";
  webPage += "<HEAD>";
  webPage += "<TITLE>Arduino GET test page</TITLE>";
  webPage += "</HEAD>";
  webPage += "<BODY>";
  webPage += "<H1>LED</H1>";
  webPage += "<FORM ACTION='/' method=get >"; //uses IP/port of web page
  webPage += "Start at: <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
  webPage += "<a href=\"submit\"><INPUT TYPE=SUBMIT NAME='submit' VALUE='Start'>";
  webPage += "</FORM>";
  webPage += "<BODY/>";
  webPage += "</HTML>";
  // preparing GPIOs
  pinMode(gpio5_pin, OUTPUT);
  digitalWrite(gpio5_pin, LOW);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  if (mdns.begin("esp8266", WiFi.localIP())) {
    Serial.println("MDNS responder started");
  server.on("/", [](){
    server.send(200, "text/html", webPage);
  server.on("/submit", [](){
    String readString = "";
    while (Serial.available()) {
      char c = Serial.read(); //gets one byte from serial buffer
      readString += c; //makes the String readString
      delay(2); //slow looping to allow buffer to fill with next character
    if(readString.length()>0){
      Serial.println(readString); //prints string to serial port out
      int pos1 = readString.indexOf('=');
      int pos2 = readString.indexOf('&');
      String newString;
      newString = readString.substring(pos1+1, pos2);
      Serial.print("newString is: ");
      Serial.println(newString);
      int val;
      val = newString.toInt();
      delay(val*1000);
      digitalWrite(gpio5_pin, HIGH);
      //delay(1000);
      Serial.print("The value sent is: ");
      Serial.println(val);
      readString=""; //clears variable for new input
      newString = ""; //clears variable for new input
  server.begin();
  Serial.println("HTTP server started");
void loop(void){
  server.handleClient();
But, you didn't share that data...
Does it ever switch on? What makes it switch off?
Hi, the LED never switches on or off. All the "Serial.println" functions don't get executed in this part of the code, either:
      String newString;
      int val;
      delay(val*1000);
      //delay(1000);
If you send the data using the server instance, is it appropriate to read the response using Serial?
Yes, we didn't notice that earlier. So how do we use "server" to read it?
RoyBlue:
RTFM?
We tried, but we cannot understand. Please help us?
Thanks
RoyBlue:
Thanks
I can't. I don't have the manual (the documentation or source code) for the libraries that you are using, and you didn't post links to them.
Sorry, but we used this: GitHub - esp8266/Arduino: ESP8266 core for Arduino and some scattered codes on forum to learn and compile our code as much as possible. Thank you!
If I had your hardware, I'd add some Serial.print() statements in the two server.on lambdas, to assure that the correct one gets called.
In the one that does something useful, I'd print the value that server.uri() returns, to see if it contained anything useful. I'd call server.args() to see how many arguments there are, and call server.arg(n) to get each one (setting n to the appropriate value, of course).
If I had your hardware, I'd add some Serial.print() statements in the two server.on lambdas, to assure that the correct one gets called. In the one that does something useful, I'd print the value that server.uri() returns, to see if it contained anything useful.
We added the Serial. print() statements and it is only working on the first server.on lambda (which is not the correct one). We printed the value of server.uri(). It only prints "/". What should we do? Thank you!
Look at the AdvancedWebServer sketch in the examples folder of that library. Observe how the handleNotFount() function gets number of arguments, argument names, and argument values using methods of the server object.
RoyBlue:
The ACTION value says to execute the script / on the Arduino. So, the first lamdba (the server.on("/" one) IS the correct one.
If you want the other one called, instead, you need to change the ACTION value.
Yes, we changed the ACTION value and it does go to the second server.on lambda. We tried out a print statement on the lambda and it worked. However, the logic and the code for LED switching on after a given time does not work. Here is that code:
      String newString;
      int val;
      delay(val*1000);
      //delay(1000);
As mentioned before, it might be because the Serial.read is not synonymous with server. What can we do? Thanks!
For me, it would be easier to follow if you posted the complete sketch every time.
No problem, thank you. We figured out the problem. It was indeed the problem that Serial.read cannot be used to server. We used server.arg(name) and solved it.
