Hi all.
I'm building a thermostat device to control two AC units in the same room. Rather than have them fight each other, I figured I'd build a controller that measures temperature and then gets two separate devices to fire the same IR command to each unit, thus unifying them.
I'm using Wemos D1 Minis, and have used ESPNOW for the wireless communication and IRRemote for the IR interface.
Testing the code, the demo code "Out the box" for Daikin ACs worked in terms of successfully sending commands that were picked up by the unit.
However with my code that included a bunch of if statements to determine which settings to use, and a 2nd tab full of the different command functions, it appeared to send a command, but the data it sent was not recognised as a Daikin protocol. If I put the IR code back into the loop somewhere, it seems to work, but I am trying to understand why it didn't work as I had originally intended. I am assuming it is something to do with timings somewhere as the process essentially relies on ESPNOW picking up a command signal and then, based on the command, going to the relevant function which would send the IR code, all outside of the loop. See below:
#include <ESP8266WiFi.h>
#include <espnow.h>
#include <Arduino.h>
#include <IRremoteESP8266.h>
#include <IRsend.h>
#include <ir_Daikin.h>
const uint16_t kIrLed = D1; // ESP8266 GPIO pin to use. Recommended: 4 (D2).
IRDaikinESP ac(kIrLed); // Set the GPIO to be used to sending the message
int red = D8;
int green = D7;
int blue = D6;
bool commandsent;
// Structure example to receive data
// Must match the sender structure
typedef struct data_struct {
int acmode;
int tempsetting;
} data_struct;
// Create a struct_message called myData
data_struct myData;
// Initialize Serial Monitor
ac.begin();
commandsent = true;
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
digitalWrite(red, LOW);
digitalWrite(green, LOW);
digitalWrite(blue, LOW);
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
WiFi.disconnect();
// Init ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
esp_now_register_recv_cb(OnDataRecv);
// Callback function that will be executed when data is received
void OnDataRecv(uint8_t *mac, uint8_t *incomingData, uint8_t len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.print("Bytes received: ");
Serial.println(len);
Serial.print("AC Mode: ");
Serial.println(myData.acmode);
Serial.print("Set Temp: ");
Serial.println(myData.tempsetting);
commandsent = false;
if ((myData.acmode == 0) && (commandsent == false)) {
turnoff();
if ((myData.acmode == 1) && (myData.tempsetting == 16) && (commandsent == false)) {
heat16();
if ((myData.acmode == 1) && (myData.tempsetting == 17) && (commandsent == false)) {
heat17();
if ((myData.acmode == 1) && (myData.tempsetting == 18) && (commandsent == false)) {
heat18();
if ((myData.acmode == 1) && (myData.tempsetting == 19) && (commandsent == false)) {
heat19();
if ((myData.acmode == 1) && (myData.tempsetting == 20) && (commandsent == false)) {
heat20();
if ((myData.acmode == 1) && (myData.tempsetting == 21) && (commandsent == false)) {
heat21();
if ((myData.acmode == 1) && (myData.tempsetting == 22) && (commandsent == false)) {
heat22();
if ((myData.acmode == 1) && (myData.tempsetting == 23) && (commandsent == false)) {
heat23();
if ((myData.acmode == 1) && (myData.tempsetting == 24) && (commandsent == false)) {
heat24();
if ((myData.acmode == 1) && (myData.tempsetting == 25) && (commandsent == false)) {
heat25();
if ((myData.acmode == 2) && (myData.tempsetting == 16) && (commandsent == false)) {
cool16();
if ((myData.acmode == 2) && (myData.tempsetting == 17) && (commandsent == false)) {
cool17();
if ((myData.acmode == 2) && (myData.tempsetting == 18) && (commandsent == false)) {
cool18();
if ((myData.acmode == 2) && (myData.tempsetting == 19) && (commandsent == false)) {
cool19();
if ((myData.acmode == 2) && (myData.tempsetting == 20) && (commandsent == false)) {
cool20();
if ((myData.acmode == 2) && (myData.tempsetting == 21) && (commandsent == false)) {
cool21();
if ((myData.acmode == 2) && (myData.tempsetting == 22) && (commandsent == false)) {
cool22();
if ((myData.acmode == 2) && (myData.tempsetting == 23) && (commandsent == false)) {
cool23();
if ((myData.acmode == 2) && (myData.tempsetting == 24) && (commandsent == false)) {
cool24();
if ((myData.acmode == 2) && (myData.tempsetting == 25) && (commandsent == false)) {
cool25();
