Hi guys,
So i worked on this project for a while and managed to have an NRF24L01/nano send t/h data on a periodic basis to another NRF/uno/esp8266 which posts it to thingspeak.com. Ive had it working for weeks even months, but I have noticed that the module doesnt play nice with my router (linksys wrt945n). Other devices experience connectivity issues like slow load times (which i believe are related to missed pings) and the router itself gets rebooted for some reason, not on a daily basis but once every week or 2 weeks.
I used to think it was my appletv or my googlehome or my old laptop which had sketchy wifi hardware cause it is old. But i tested the same scenario without those devices plugged in and it still happened. Yesterday I unplugged the Rx NRF/uno/esp8266 unit and it has been smooth sailing so far.
Anyone experience similar issues with esp8266 (esp01) modules?
It happens with our without the mac reserved-IP on the router for that module.
This is the code on the Rx which is the unit with the ESP8266 esp01:
/////////////////////////////////////////////////////////////////////////////////////////////////////FROM WORKING RECEIVE
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
/////////////////////////////////////////////////////////////////////////////////////////////////////AAAAAAAAAAAAA
#include <SoftwareSerial.h>
#define RX 10
#define TX 11
String AP = "WIFI_NAME"; // CHANGE ME
String PASS = "WIFI_PASSWORD"; // CHANGE ME
String API = "YOUR_API_KEY"; // CHANGE ME
String HOST = "api.thingspeak.com";
String PORT = "80";
String field1 = "field1";
String field2 = "field2";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int valSensor = 1;
SoftwareSerial esp8266Radio(RX,TX);
#define CE_PIN 7
#define CSN_PIN 8
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN);
struct package{
float humedad = 0;
float temperatura = 0;
typedef struct package Package;
Package dataReceived;
bool newData = false;
//Must move code to a wifi-startup()<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<Will run everytime mcu wakes up
//setup radio receive stuff
setupRadio();
//setup esp for posting to cloud
esp8266Radio.begin(115200);
sendCommand("AT",5,"OK");
sendCommand("AT+CWMODE=1",5,"OK");
sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK");
void setupRadio(){
pinMode(10,OUTPUT);
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
lcd.init();
lcd.init();
lcd.backlight();
//get data from radio first...
getData();
showData();
void sendCommand(String command, int maxTime, char readReplay[]) {//<<<<<<<<<<<<<<<<<<<helper f(x)
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while(countTimeCommand < (maxTime*1))
esp8266Radio.println(command);//at+cipsend
if(esp8266Radio.find(readReplay))//ok
found = true;
countTimeCommand++;
if(found == true)
Serial.println("OYI");
countTrueCommand++;
countTimeCommand = 0;
if(found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived.humedad);
Serial.println(dataReceived.temperatura);
lcd.setCursor(1,0);
lcd.print(dataReceived.humedad);
lcd.setCursor(1,1);
lcd.print(dataReceived.temperatura);
newData = false;
postDataCloud();
void postDataCloud(){
String getData = "GET /update?api_key="+ API +"&"+ field1 +"="+String(dataReceived.humedad)+"&"+ field2 +"="+String(dataReceived.temperatura);
sendCommand("AT+CIPMUX=1",5,"OK");
sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK");
sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">");
esp8266Radio.println(getData);delay(1500);countTrueCommand++;
sendCommand("AT+CIPCLOSE=0",5,"OK");
