Esp8266 internet clock
Hi all
I have downloaded code from the net and I am applying it to an esp8266 but I get an error D3 not declared in this scope and the error message will also say the same about D2 & D4. Any assistance would be appreciated
cheers
Nick
 * WiFi Internet clock (NTP) with ESP8266 NodeMCU (ESP-12E) board and
 *   ST7735 TFT display.
 * This is a free software with NO WARRANTY.
 * https://simple-circuit.com/
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <NTPClient.h>        // include NTPClient library
#include <TimeLib.h>          // Include Arduino time library
#include <Adafruit_GFX.h>     // include Adafruit graphics library
#include <Adafruit_ST7735.h>  // include Adafruit ST7735 TFT library
// ST7735 TFT module connections
#define TFT_RST   D4     // TFT RST pin is connected to NodeMCU pin D4 (GPIO2)
#define TFT_CS    D3     // TFT CS  pin is connected to NodeMCU pin D3 (GPIO0)
#define TFT_DC    D2     // TFT DC  pin is connected to NodeMCU pin D2 (GPIO4)
// initialize ST7735 TFT library with hardware SPI module
// SCK (CLK) ---> NodeMCU pin D5 (GPIO14)
// MOSI(DIN) ---> NodeMCU pin D7 (GPIO13)
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// set WiFi network SSID and password
const char *ssid     = "YOUR SSID";
const char *password = "YOUR PASSWORD";
WiFiUDP ntpUDP;
// 'time.nist.gov' is used (default server) with +1 hour offset (3600 seconds) 60 seconds (60000 milliseconds) update interval
NTPClient timeClient(ntpUDP, "time.nist.gov", 3600, 60000);
unsigned long unix_epoch;
void setup(void)
  tft.initR(INITR_BLACKTAB);     // initialize a ST7735S chip, black tab
  tft.fillScreen(ST7735_BLACK);  // fill screen with black color
  tft.drawFastHLine(0, 44,  tft.width(), ST7735_BLUE);    // draw horizontal blue line at position (0, 44)
  tft.setTextColor(ST7735_WHITE, ST7735_BLACK);     // set text color to white and black background
  tft.setTextSize(1);                 // text size = 1
  tft.setCursor(19, 10);              // move cursor to position (43, 10) pixel
  tft.print("ESP8266 NodeMCU");
  tft.setCursor(4, 27);               // move cursor to position (4, 27) pixel
  tft.print("Wi-Fi Internet Clock");
  WiFi.begin(ssid, password);
  Serial.print("Connecting.");
  tft.setCursor(0, 54);              // move cursor to position (4, 27) pixel
  tft.print("Connecting..");
  while ( WiFi.status() != WL_CONNECTED ) {
    Serial.print(".");
  Serial.println("connected");
  tft.print("connected");
  delay(2000);
  tft.fillRect(0, 54, tft.width(), 8, ST7735_BLACK);
  tft.drawFastHLine(0, 102, tft.width(), ST7735_BLUE);  // draw horizontal blue line at position (0, 102)
  tft.setTextSize(2);                                   // text size = 2
  tft.setTextColor(ST7735_MAGENTA, ST7735_BLACK);       // set text color to magenta and black background
  tft.setCursor(37, 112);                               // move cursor to position (37, 112) pixel
  tft.print("TIME:");
  timeClient.begin();
void RTC_display()
  char dow_matrix[7][10] = {"SUNDAY", "MONDAY", "TUESDAY", "WEDNESDAY", "THURSDAY", "FRIDAY", "SATURDAY"};
  byte x_pos[7] = {29, 29, 23, 11, 17, 29, 17};
  static byte previous_dow = 0;
  // print day of the week
  if( previous_dow != weekday(unix_epoch) )
    previous_dow = weekday(unix_epoch);
    tft.fillRect(11, 55, 108, 14, ST7735_BLACK);     // draw rectangle (erase day from the display)
    tft.setCursor(x_pos[previous_dow-1], 55);
    tft.setTextColor(ST7735_CYAN, ST7735_BLACK);     // set text color to cyan and black background
    tft.print( dow_matrix[previous_dow-1] );
  // print date
  tft.setCursor(4, 79);
  tft.setTextColor(ST7735_YELLOW, ST7735_BLACK);     // set text color to yellow and black background
  tft.printf( "%02u-%02u-%04u", day(unix_epoch), month(unix_epoch), year(unix_epoch) );
  // print time
  tft.setCursor(16, 136);
  tft.setTextColor(ST7735_GREEN, ST7735_BLACK);     // set text color to green and black background
  tft.printf( "%02u:%02u:%02u", hour(unix_epoch), minute(unix_epoch), second(unix_epoch) );
// main loop
  timeClient.update();
  unix_epoch = timeClient.getEpochTime();   // get UNIX Epoch time
  RTC_display();
  delay(200);    // wait 200ms
// end of code.
Which 8266 do you have?
Which 8266 are you compiling for?
(I'd've known this if you'd posted your error message)
Looks as if you are not the first to encounter this problem:
https://github.com/wemos/D1_mini_Examples/issues/21
According to this thread you may have to replace the pins like this
#define TFT_RST   2    // TFT RST pin is connected to NodeMCU pin D4 (GPIO2)
#define TFT_CS    0     // TFT CS  pin is connected to NodeMCU pin D3 (GPIO0)
#define TFT_DC    4     // TFT DC  pin is connected to NodeMCU pin D2 (GPIO4)
Which ESP8266 board have you got selected in the IDE ?
There is often confusion over pin numbers on ESP8266 boards but the code compiles and runs OK on my D1 mini using the D* pin numbers
Hi UKHeliBob
In ESP8266 Boards (3.0.2) I am using the very first in the listing as I dont see any other option that looks to fit the bill. The board I am using is from Jaycar electronics (aust) and is called an ESP8266 wiFi Mini
I am using ide 1.8.19
Try selecting Wemos D1 R2 & mini as the board
I have tried to download the relevant boards but I'm not sure if they are actually arrivingbecause of the java error in one of these photos
fr_7540_size640
fr_7539_size640
I don't even have the Wemos D1 R2 option
From the screenshot it looks like you already have the 8266 boards installed. Exactly which ESP8266 board have you got ?
This is all the info I can get
Hi AWOL here is the error message
Arduino: 1.8.19 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
D:\Downloads\Arduino IDE\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware D:\Downloads\Arduino IDE\arduino-1.8.19\hardware -hardware C:\Users\spark\AppData\Local\Arduino15\packages -tools D:\Downloads\Arduino IDE\arduino-1.8.19\tools-builder -tools D:\Downloads\Arduino IDE\arduino-1.8.19\hardware\tools\avr -tools C:\Users\spark\AppData\Local\Arduino15\packages -built-in-libraries D:\Downloads\Arduino IDE\arduino-1.8.19\libraries -libraries C:\Users\spark\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M64,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\spark\AppData\Local\Temp\arduino_build_792463 -warnings=none -build-cache C:\Users\spark\AppData\Local\Temp\arduino_cache_60121 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08 -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.0-newlib4.0.0-gnu23-48f7b08.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08 -prefs=runtime.tools.python3.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.0-newlib4.0.0-gnu23-48f7b08 -prefs=runtime.tools.mkspiffs-3.0.0-newlib4.0.0-gnu23-48f7b08.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.0-newlib4.0.0-gnu23-48f7b08 -verbose C:\Users\spark\Documents\Arduino\ESP8266__internet_clock\ESP8266__internet_clock.ino
D:\Downloads\Arduino IDE\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware D:\Downloads\Arduino IDE\arduino-1.8.19\hardware -hardware C:\Users\spark\AppData\Local\Arduino15\packages -tools D:\Downloads\Arduino IDE\arduino-1.8.19\tools-builder -tools D:\Downloads\Arduino IDE\arduino-1.8.19\hardware\tools\avr -tools C:\Users\spark\AppData\Local\Arduino15\packages -built-in-libraries D:\Downloads\Arduino IDE\arduino-1.8.19\libraries -libraries C:\Users\spark\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M64,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\spark\AppData\Local\Temp\arduino_build_792463 -warnings=none -build-cache C:\Users\spark\AppData\Local\Temp\arduino_cache_60121 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08 -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.0-newlib4.0.0-gnu23-48f7b08.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.0-newlib4.0.0-gnu23-48f7b08 -prefs=runtime.tools.python3.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.0-newlib4.0.0-gnu23-48f7b08 -prefs=runtime.tools.mkspiffs-3.0.0-newlib4.0.0-gnu23-48f7b08.path=C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.0-newlib4.0.0-gnu23-48f7b08 -verbose C:\Users\spark\Documents\Arduino\ESP8266__internet_clock\ESP8266__internet_clock.ino
Using board 'generic' from platform in folder: C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0
Using core 'esp8266' from platform in folder: C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0
Invalid library found in C:\Users\spark\Documents\Arduino\libraries\GPS-Speedometer-master: no headers files (.h) found in C:\Users\spark\Documents\Arduino\libraries\GPS-Speedometer-master
Detecting libraries used...
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0 ESP8266WiFi]
ResolveLibrary(ESP8266WiFi.h)
  -> candidates: [ESP8266WiFi@1.0 ESP8266WiFi]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
Alternatives for NTPClient.h: [NTPClient-master@3.2.0 ESP8266_Weather_Station@2.1.0]
ResolveLibrary(NTPClient.h)
  -> candidates: [NTPClient-master@3.2.0 ESP8266_Weather_Station@2.1.0]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
Alternatives for TimeLib.h: [Time-master@1.6 Time@1.6 TimeLib]
ResolveLibrary(TimeLib.h)
  -> candidates: [Time-master@1.6 Time@1.6 TimeLib]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit-GFX-Library-master@1.9.0 arduino_156261@1.10.10 arduino_35462@1.10.6 Adafruit_GFX_Library@1.10.13]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit-GFX-Library-master@1.9.0 arduino_156261@1.10.10 arduino_35462@1.10.6 Adafruit_GFX_Library@1.10.13]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
Alternatives for Adafruit_ST7735.h: [Adafruit-ST7735-Library-master@1.5.18 Adafruit_ST7735_and_ST7789_Library@1.7.1 arduino_711299@1.7.4 arduino_714057@1.7.1]
ResolveLibrary(Adafruit_ST7735.h)
  -> candidates: [Adafruit-ST7735-Library-master@1.5.18 Adafruit_ST7735_and_ST7789_Library@1.7.1 arduino_711299@1.7.4 arduino_714057@1.7.1]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\BearSSLHelpers.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\CertStoreBearSSL.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFi.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiAP.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGeneric.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGratuitous.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiMulti.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA-WPS.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiScan.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\WiFiClientSecureBearSSL.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\WiFiServerSecureBearSSL.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src\\enable_wifi_at_boot_time.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master\\NTPClient.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.11.1 arduino_794816@1.7.3]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.11.1 arduino_794816@1.7.3]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library\\Adafruit_ST7735.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library\\Adafruit_ST7789.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library\\Adafruit_ST77xx.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire\\Wire.cpp" -o nul
Generating function prototypes...
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"D:\\Downloads\\Arduino IDE\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" "C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/signing.py" --mode header --publickey "C:\\Users\\spark\\Documents\\Arduino\\ESP8266__internet_clock/public.key" --out "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core/Updater_Signing.h"
"C:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.0-newlib4.0.0-gnu23-48f7b08/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/lwip2/include" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463/core" -c -w -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\cores\\esp8266" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\variants\\generic" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\NTPClient-master" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\TimeLib" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\SPI" "-IC:\\Users\\spark\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\spark\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.0\\libraries\\Wire" "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp" -o "C:\\Users\\spark\\AppData\\Local\\Temp\\arduino_build_792463\\sketch\\ESP8266__internet_clock.ino.cpp.o"
ESP8266__internet_clock:19:19: error: 'D3' was not declared in this scope
   19 | #define TFT_CS    D3     // TFT CS  pin is connected to NodeMCU pin D3 (GPIO0)
C:\Users\spark\Documents\Arduino\ESP8266__internet_clock\ESP8266__internet_clock.ino:24:39: note: in expansion of macro 'TFT_CS'
   24 | Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
ESP8266__internet_clock:20:19: error: 'D2' was not declared in this scope
   20 | #define TFT_DC    D2     // TFT DC  pin is connected to NodeMCU pin D2 (GPIO4)
C:\Users\spark\Documents\Arduino\ESP8266__internet_clock\ESP8266__internet_clock.ino:24:47: note: in expansion of macro 'TFT_DC'
ESP8266__internet_clock:18:19: error: 'D4' was not declared in this scope
   18 | #define TFT_RST   D4     // TFT RST pin is connected to NodeMCU pin D4 (GPIO2)
C:\Users\spark\Documents\Arduino\ESP8266__internet_clock\ESP8266__internet_clock.ino:24:55: note: in expansion of macro 'TFT_RST'
Multiple libraries were found for "Adafruit_I2CDevice.h"
 Used: C:\Users\spark\Documents\Arduino\libraries\Adafruit_BusIO
 Not used: C:\Users\spark\Documents\Arduino\libraries\arduino_794816
Multiple libraries were found for "ESP8266WiFi.h"
 Used: C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0\libraries\ESP8266WiFi
 Not used: C:\Users\spark\Documents\Arduino\libraries\ESP8266WiFi
Multiple libraries were found for "NTPClient.h"
 Used: C:\Users\spark\Documents\Arduino\libraries\NTPClient-master
 Not used: C:\Users\spark\Documents\Arduino\libraries\ESP8266_Weather_Station
Multiple libraries were found for "TimeLib.h"
 Used: C:\Users\spark\Documents\Arduino\libraries\TimeLib
 Not used: C:\Users\spark\Documents\Arduino\libraries\Time-master
Multiple libraries were found for "Adafruit_GFX.h"
 Used: C:\Users\spark\Documents\Arduino\libraries\Adafruit_GFX_Library
 Not used: C:\Users\spark\Documents\Arduino\libraries\Adafruit-GFX-Library-master
 Not used: C:\Users\spark\Documents\Arduino\libraries\arduino_156261
 Not used: C:\Users\spark\Documents\Arduino\libraries\arduino_35462
Multiple libraries were found for "Adafruit_ST7735.h"
 Used: C:\Users\spark\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library
 Not used: C:\Users\spark\Documents\Arduino\libraries\Adafruit-ST7735-Library-master
 Not used: C:\Users\spark\Documents\Arduino\libraries\arduino_711299
 Not used: C:\Users\spark\Documents\Arduino\libraries\arduino_714057
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0\libraries\ESP8266WiFi
Using library NTPClient-master at version 3.2.0 in folder: C:\Users\spark\Documents\Arduino\libraries\NTPClient-master
Using library TimeLib in folder: C:\Users\spark\Documents\Arduino\libraries\TimeLib (legacy)
Using library Adafruit_GFX_Library at version 1.10.13 in folder: C:\Users\spark\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_ST7735_and_ST7789_Library at version 1.7.1 in folder: C:\Users\spark\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library
Using library SPI at version 1.0 in folder: C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0\libraries\SPI
Using library Adafruit_BusIO at version 1.11.1 in folder: C:\Users\spark\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\spark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0\libraries\Wire
exit status 1
You haven't read these Jacar instructions carefully enough. It tells you exactly which board type to select.
The board to select for XC3802 is . . .
Probably $24 AUS or NZ (but still).
"WeMosD1R1" looks like
Fancy that. The board is the same form factor as the D1 mini and even has that written on it
Hi 6v6gt
Thank you for pointing that out but I did have the address in the "Preferences bar but there was no comma separating it from the next item in the line. I now have the correct options available in the "Board" selection area but I am still getting errors which I I am having difficulty deciphering.I will post the new error report tomorrow
Which board have you got selected now when compiling ?
If you click on the icon to the right of the Additional Boards dialogue
Then you can edit the list of board files in a resizable window, one per line, which is much easier
This is the same thing but a bit more readable.
From the error messages you posted previously, it looked like you had got quite far but had selected the Generic ESP8266 board which may not accept the alternative pin numbering which was the cause of your original problem.
Jaycar itemWell, that's what you pay for having one in stock in your local store. including mine apparently :grin: I sometimes even drop in there to check out their "disposals" bin. :wink:
$5.33 with GST from Aliexpress.
Used to be more like half that before Covid and the government/ Scomo calling China out.
