Testing. Data will be here
Since it is at work I cannot have a public access to the server. I will have it when I will move it to my home.
This is just a test for RTC and logging.
Good morning,
Re-visited zoomx's application of "NTP with Timezones and have a successful working sketch, "NTP_Observations_SPIFFS.ino"
Included in the attachment are the sketch, "LOG.TXT (portion actually logging during testing) and output of the Serial Monitor (during testing.)
Note: Time keeping is now accomplished with software using NTP time server.
William
NTP Observatons_SPPIFFS .zip (15.8 KB)
Server and sensor running "NTP_Observations_SPIFFS.ino" with No Real Time Clock!
Server has been online since 7/29/2017; all time keeping functions are handled by NTP time server.
Thank you "zoomx" for applying NTP and Timezones to project!
Check out thefour graphs from "ThingSpeak.com;" let mouse hover over data point on graph to reveal value and time of data entry:
WiFi Client/Server Based --ESP8266
Domain Hosted, WiFi Client.Server Based --ESP8266
William
zoomx:
I read that UDP packet has a checksum so I believe that the packet received should be correct. If packet is not correct it should be discarded and it's like not receiving any packet.
I am wrong and this assumption seems false.
In Serial output --modded file.tx
packet received, length=12
Seconds since Jan 1 1900 = 0
Unix time = 2085978496
Data written to log 02/07/2036 , 01:30:00
there was a packet that was long 12 bytes instead of 48.
So packet with lenght different from 48 must be discarded.
I apologize William, you wrote this already.
@ Zoomx
No need to apologize zoomx. Thank you for all your time, coding, and community participation.
Logging of Data now has priority after too many missed 15 -minute intervals.
This version has been tested over three days; much improved, over previous versions. All time keeping is NTP based; no Real Time Clock!
William
Serial Output --log priority --8-11-2017.txt (73.6 KB)
Testing --LOG.TXT (47.4 KB)
NTP_Observations_SPIFFS.zip (11.7 KB)
3 Minute Video of project
William
Current version has been online since 08/08/2017 @ 23:31 EST with little interruption. Developement board is a RobotDyn Wifi D1 R2 from Source of board
Attached "NTP_Observations_SPIFFS.zip" is the 08/08/2017 @ 23:31 EST version.
October 2, 2017 Update:
"NTP_Observations_SPIFFS.ino" 08/08/2017 @ 23:31 EST continues to remain online. Last version change date was 08/08/2017 @ 23:31 EST.
Current version has performed above and beyond my expectations. Very good reliability. Fast downloads. Fast Watchdog resets on the rare occurrence when one happens.
William
Improved Wake time in response to page request.
Improvements to simplify editing page links.
List of line numbers requiring editing.
NTP_Observations_SPIFFS.zip (12.1 KB)
Update 11/23/2017
Added code for occasion when no NTP Packet is received, to request a new Packet to be sent.
Added SERVER.TXT file for date and time of Server starts.
Previous version of project code is: "Nov_23_2017__NTP_Observations_SPIFFS.ino."
Installed version of project code is: "Dec_9_2017__NTP_Observations_SPIFFS.ino."
William
Nov_23_2017__NTP_Observations_SPIFFS.zip (12.2 KB)
Dec_9_2017__NTP_Observations_SPIFFS.ino (50.2 KB)
Some how my device was blocked at my Gateway.
Apologies to anyone that tried to connect and was unable to connect.
No changes to software since the last update.
William
New feature: Hosted website gets updates every 15 minutes. Very little additional code to project by using ESP8266HTTPClient library.
Website is on ".000webhostapp.com" free, educational Domain:
Stephan Borsay's article on Hackster.io was the inspiration for this additional feature.
William
NTP_Web_Interface.zip (13.8 KB)
Thanks for the update William,
I will read the links you provided!
Completed design of Website for project. Driving element of web sit is the following code:
<?php
ESP8266: send data to your Domain
Uses POST command to send BME280 data to a designated website
The circuit:
* BME280
* Post to Domain
Original version of this code by Stephan Borsay
Modified with HTML and CSS by techno500 for use with BME280 along with Arduino/ESP8266 sketch:
"NTP_Web_Interface.ino."
date_default_timezone_set("America/Indianapolis");
$TimeStamp = date("Y-m-d h:i:sa");
if( $_REQUEST["fahren"] || $_REQUEST["heat"] || $_REQUEST["hum"] || $_REQUEST["dewpt"]
|| $_REQUEST["cpressure"] || $_REQUEST["bars"] )
echo " The Temperature is: ". $_REQUEST['fahren']. "F.
echo " The Heat Index is: ". $_REQUEST['heat']. " Heat Index
echo " The Temperature is: ". $_REQUEST['hum']. " hum
echo " The Dew Point is: ". $_REQUEST['dewpt']. " Dew Point
echo " The Barometric Pressure is: ". $_REQUEST['cpressure']. " in. HG.
echo " The Barometric Pressure is: ". $_REQUEST['bars']. " millibars
echo " The Altitude is: 824 Feet
$var1 = $_REQUEST['fahren'];
$var2 = $_REQUEST['heat'];
$var3 = $_REQUEST['hum'];
$var4 = $_REQUEST['dewpt'];
$var5 = $_REQUEST['cpressure'];
$var6 = $_REQUEST['bars'];
//$var7 = $_REQUEST['altit'];
$WriteMyRequest=
"<html>".
"<head>".
"<body>".
"<style>".
"body { background: #561C0E no-repeat fixed center;}".
"a,h2,h3 {color: #ffffff;}".
"font-weight: bold;}".
"</style>".
"<title>Observations</title>".
"<h2>".
"Observations".
"<p>Treyburn Lakes
"Indianapolis, IN
"46239</p></h2>
"<p><h3>Last update: " . $TimeStamp . "</p>".
"<p> The Temperature is : " . $var1 . " F. </p>".
"<p>And the Heat Index is : " . $var2 . " F. </p>".
"<p>And the Humidity : " . $var3 . " % </p>".
"<p>And The Dew Point is : " . $var4 . " F. </p>".
"<p>And The Barometric Pressure is : " . $var5 . " in. HG. </p>".
"<p>And The Barometric Pressure is : " . $var6 . " mb</p>".
"<p>And The Altitude is : 824 Feet </p>
". // Altitude as read by GPS for project location
"<a href='https://pathToAbout.php'>About</h3></a>".
"</head>".
"</body>".
"</html>";
file_put_contents('display.html', $WriteMyRequest);
This is the PHP code that creates the "Observations" menu option of the website.
PHP code above receives the POST from the "NTP_Web_Interface.ino" sketch. POST is developed with use of the "ESP8266HTTPClient" library. Project is unique in the fact that it does not use a Real Time Clock. Every 15 minutes; PHP code rewrites the "Observations" HTML page. Only the "ESP8266" development board and the BME280 are required making for a real low cost project! All timing requirements are provided by using Network Time Protocol and a time server to derive the time and date used in the sketch.
Over the time I have been developing this project; have had allot of help from members of the various forums. Without their help this project would have been impossible. To those that helped and the owners of the various forums; thank you, your help most appreciated!
Attached is the sketch and the php code.
William
Add screen capture
NTP_Web_Interface.zip (14 KB)
Nice project Techno!!!
That BME280 sensor is really nice! I noticed on your observations page the temp is off the scale:
Treyburn Lakes
Indianapolis, IN, US
Last update: 2018-02-06 05:30:02pm
The Temperature is : -230.62 F.
And the Heat Index is : -228.32 F.
And the Humidity : 100.00 %
And The Dew Point is : -230.62 F.
And The Barometric Pressure is : 35.13 in. HG.
And The Barometric Pressure is : 1189.80 mb
@rxpc Thank you for bringing this to my attention; caused by faulty Dupont jumper on the BME280 sensor. I need to get this project off of breadboard and on to a printed circuit board. Have started "Eagle" class on "Udemy.com" for creating printed circuit boards. First project in "Eagle" will be to create a PCB for "NTP_Web_Interface.ino" project!
William
Great! I'm glad you replied...I was wondering if the ice age was upon us!
Good luck with your class.
I made some PCB's a few years back with a laser printer. They make a nice small
footprint for your projects.
Weather Data is displayed and updated every fifthteen minutes, Data is pulled from server running on RobotDyn WiFi D1 R2. Pages "live" on a domain, website.
Both websites are running simultaneously from the same sketch! Sketch does not require a Real Time Clock! NTP Protocol and time server are used for all timing requirements!
See previous POST for "NTP_Web_Interface.zip" sketch and PHP file that receives data from the server on the Domain, hosted web site.
Correct filename.
schufti of the ESP8266.com Forum introduced me to two libraries for the ESP8266; "sys/time.h" and "time.h" these two libraries are used with NTP Time server to sync time with the ESP8266. Should be noted this requires ESP8266 core 2.4.1 version; which can be installed using the "Arduino IDE" "Board Manager."
I am having issues with the hosted web site; once this is resolved, the website should be back online.
"NTP_Web_Interface code has been renamed to "Fast_Time_Web_Interface_v4.ino." Current date of version is 04/11/2018 @ 17:03 PM.
William
Fast_Time_Web_Interface_v4.zip (11.4 KB)
ESP8266_Time_Sync.ino (2.96 KB)
I will check these libraries!
Thanks William!
Edit: Wow! seems much simpler than using UDP, TimeLib and TimeZone libraries.
