ESP8266 is not connecting to my wifi
Recently, I bought an ESP8266 wifi module and connected it with my ARDUINO mega.I am trying to connect my ESP8266 module to my HOme wifi. The code got compiled and uploaded without any error. But the wifi module could not connect to the internet instead i am able to see the hotspot of that wifi module when checking with another device.
My question is ,do I need to flash the wifi module after buying it before using?
Error:-
19:31:27.573 -> ESP CWMODE SET FAILED
19:31:37.584 -> timeout 1
19:31:37.584 -> ESP SSID SET FAILED
19:31:37.584 -> CHECKING FOR AN IP ADDRESS
19:31:47.572 -> timeout 1
19:31:47.572 -> IP ADDRESS FAILtimeout 1
19:31:52.583 -> ESP CIPMUX SET FAILED
19:31:53.581 -> CONNECTING
19:31:58.585 -> timeout 1
19:31:58.585 -> FAILED TO CONNECT
19:32:03.595 -> timeout 1
19:32:03.595 -> ESP CHECK FAILED
19:32:08.605 -> timeout 1
19:32:08.605 -> ESP RESET FAILED
19:32:13.582 -> timeout 1
19:32:13.582 -> ESP CWMODE SET FAILED
19:32:23.577 -> timeout 1
19:32:23.610 -> ESP SSID SET FAILED
19:32:23.610 -> CHECKING FOR AN IP ADDRESS
19:32:33.598 -> timeout 1
19:32:33.598 -> IP ADDRESS FAILtimeout 1
19:32:38.576 -> ESP CIPMUX SET FAILED
19:32:39.603 -> CONNECTING
19:32:44.611 -> timeout 1
19:32:44.611 -> FAILED TO CONNECT
19:32:49.581 -> timeout 1
19:32:49.581 -> ESP CHECK FAILED
19:32:54.594 -> timeout 1
19:32:54.594 -> ESP RESET FAILED
19:32:59.606 -> timeout 1
19:32:59.606 -> ESP CWMODE SET FAILED
19:33:09.599 -> timeout 1
19:33:09.599 -> ESP SSID SET FAILED
19:33:09.599 -> CHECKING FOR AN IP ADDRESS
At the very least you need to tell it your Wi-Fi credentials.
Very difficult to help without knowing what you have bought, an ESP8266 is a Wi-Fi capable micro-controller, as to what module you have bought with the ESP8266 at its core we can only guess.
Please provide a lot more information, such as exactly what you have bought, how you have programmed it including the code you used, in code tags </>, as per the forum instructions How to get the best out of this forum
I bought ESP8266-03
Here is the code that I used to connect
//Include the needed library, we will use softer serial communication with the ESP8266
#include <SoftwareSerial.h>
#include <avr/power.h>
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4); //sometimes the LCD adress is not 0x3f. Change to 0x27 if it dosn't work.
//Define the used
#define ESP8266_RX 10  //Connect the TX pin from the ESP to this RX pin of the Arduino
#define ESP8266_TX 11  //Connect the TX pin from the Arduino to the RX pin of ESP
int LED1 = 2;
int LED2 = 3;
int LED3 = 4;
int LED4 = 5;
int LED5 = 6;
int Potentiometer_1 = A0;
int Potentiometer_2 = A1;
int Potentiometer_3 = A2;
int Potentiometer_4 = A3;
int switch1 = 7;
int switch2 = 8;
int switch3 = 9;
///////////////////////////////Variables you must change according to your values/////////////////////////////////////////////////////////
//Add your data: SSID + KEY + host + location + id + password
const char SSID_ESP[] = "eraus";         //Give EXACT name of your WIFI
const char SSID_KEY[] = "D3VIL@912";             //Add the password of that WIFI connection
const char* host = "homiecube.000webhostapp.com/";  //Add the host without "www" Example: electronoobs.com
String NOOBIX_id = "99999";                     //This is the ID you have on your database, I've used 99999 becuase there is a maximum of 5 characters
String NOOBIX_password = "12345";               //Add the password from the database, also maximum 5 characters and only numerical values
String location_url = "/TX.php?id=";            //location of your PHP file on the server. In this case the TX.php is directly on the first folder of the server
//If you have the files in a different folder, add thas as well, Example: "/ESP/TX.php?id="     Where the folder is ESP
//Used variables in the code
String url = "";
String URL_withPacket = "";
unsigned long multiplier[] = {1, 10, 100, 1000, 10000, 100000, 1000000, 10000000, 100000000, 1000000000};
//MODES for the ESP
const char CWMODE = '1';//CWMODE 1=STATION, 2=APMODE, 3=BOTH
const char CIPMUX = '1';//CWMODE 0=Single Connection, 1=Multiple Connections
//Define the used functions later in the code, thanks to Kevin Darrah, YT channel:  https://www.youtube.com/user/kdarrah1234
boolean setup_ESP();
boolean read_until_ESP(const char keyword1[], int key_size, int timeout_val, byte mode);
void timeout_start();
boolean timeout_check(int timeout_ms);
void serial_dump_ESP();
boolean connect_ESP();
void connect_webhost();
unsigned long timeout_start_val;
char scratch_data_from_ESP[20];//first byte is the length of bytes
char payload[200];
byte payload_size = 0, counter = 0;
char ip_address[16];
//Variable to SEND to the DATABASE
bool sent_bool_1 = 0;
bool sent_bool_2 = 0;
bool sent_bool_3 = 0;
int  sent_nr_1 = 0;
int  sent_nr_2 = 0;
int  sent_nr_3 = 0;
int  sent_nr_4 = 0;
int  sent_nr_5 = 0;
//Variable RECEIVED from the DATABASE
bool received_bool_1 = 0;
bool received_bool_2 = 0;
bool received_bool_3 = 0;
bool received_bool_4 = 0;
bool received_bool_5 = 0;
int  received_nr_1 = 0;
int  received_nr_2 = 0;
int  received_nr_3 = 0;
int  received_nr_4 = 0;
int  received_nr_5 = 0;
String received_text = "";
//Store received chars in this variables
char t1_from_ESP[5];  //For time from web
char d1_from_ESP[2];  //For received_bool_2
char d2_from_ESP[2];  //For received_bool_2
char d3_from_ESP[2];  //For received_bool_3
char d4_from_ESP[2];  //For received_bool_4
char d5_from_ESP[2];  //For received_bool_5
char d9_from_ESP[6];  //For received_nr_1
char d10_from_ESP[6]; //For received_nr_2
char d11_from_ESP[6]; //For received_nr_3
char d12_from_ESP[6]; //For received_nr_4
char d13_from_ESP[6]; //For received_nr_5
char d14_from_ESP[300]; //For received_text
//DEFINE KEYWORDS HERE
const char keyword_OK[] = "OK";
const char keyword_Ready[] = "Ready";
const char keyword_no_change[] = "no change";
const char keyword_blank[] = "#&";
const char keyword_ip[] = "192.";
const char keyword_rn[] = "\r\n";
const char keyword_quote[] = "\"";
const char keyword_carrot[] = ">";
const char keyword_sendok[] = "SEND OK";
const char keyword_linkdisc[] = "Unlink";
const char keyword_t1[] = "t1";
const char keyword_b1[] = "b1";
const char keyword_b2[] = "b2";
const char keyword_b3[] = "b3";
const char keyword_b4[] = "b4";
const char keyword_b5[] = "b5";
const char keyword_n1[] = "n1";
const char keyword_n2[] = "n2";
const char keyword_n3[] = "n3";
const char keyword_n4[] = "n4";
const char keyword_n5[] = "n5";
const char keyword_n6[] = "n6";
const char keyword_doublehash[] = "##";
SoftwareSerial ESP8266(ESP8266_RX, ESP8266_TX);// rx tx
void setup() { //        SETUP     START
  lcd.init();                 //Init the LCD
  lcd.backlight();            //Activate backlight
  //Pin Modes for ESP TX/RX
  pinMode(ESP8266_RX, INPUT);
  pinMode(ESP8266_TX, OUTPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  pinMode(LED5, OUTPUT);
  pinMode(Potentiometer_1, INPUT);
  pinMode(Potentiometer_2, INPUT);
  pinMode(Potentiometer_3, INPUT);
  pinMode(Potentiometer_4, INPUT);
  pinMode(switch1, INPUT);
  pinMode(switch2, INPUT);
  pinMode(switch3, INPUT);
  digitalWrite(LED1, LOW);
  digitalWrite(LED2, LOW);
  digitalWrite(LED3, LOW);
  digitalWrite(LED4, LOW);
  digitalWrite(LED5, LOW);
  ESP8266.begin(115200);//default baudrate for ESP
  ESP8266.listen();//not needed unless using other software serial instances
  Serial.begin(115200); //for status and debug
  delay(2000);//delay before kicking things off
  setup_ESP();//go setup the ESP
  sent_nr_1 = analogRead(Potentiometer_1);
  sent_nr_1 = analogRead(Potentiometer_2);
  sent_nr_1 = analogRead(Potentiometer_3);
  sent_nr_1 = analogRead(Potentiometer_4);
  sent_bool_1 = digitalRead(switch1);
  sent_bool_2 = digitalRead(switch2);
  sent_bool_3 = digitalRead(switch3);
  send_to_server_1();
  digitalWrite(LED1, received_bool_1);
  digitalWrite(LED2, received_bool_2);
  digitalWrite(LED3, received_bool_3);
  digitalWrite(LED4, received_bool_4);
  digitalWrite(LED5, received_bool_5);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("N1: "); lcd.print(received_nr_1); lcd.print("  N2: "); lcd.print(received_nr_2);
  lcd.setCursor(0, 1);
  lcd.print("N3: "); lcd.print(received_nr_3); lcd.print("  N4: "); lcd.print(received_nr_4);
  delay(1000);//5 seconds between tries
    send_to_server_2();
    digitalWrite(LED1,received_bool_1);
    digitalWrite(LED2,received_bool_2);
    digitalWrite(LED3,received_bool_3);
    digitalWrite(LED4,received_bool_4);
    digitalWrite(LED5,received_bool_5);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    send_to_server_3();
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    send_to_server_4();
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
  send_to_server_5();
  lcd.clear();
  lcd.print(received_text);
}//End of the main loop
Thanks.
I'm no familiar with that one, hopefully someone else can be more helpful.
Thank you for the response.Hope I receive help from someone.
without this function, it is still a mystery
actually all these are missing
so are these 4 function, but at least they are commented out
send_to_server_4();
Hello,
that means you want to use the standard AT Software on the ESP modul. So you have to study the manual for that.
ist not simple to to that, and the possibilitys are closed.
Let me tell you that is not a good Idea , because it make not fun.
Use any other ESP borad and do the complete project on this.
Heinz
PS sorry for my broken enlish
