ESP8266 keeps crashing on sscanf()
I am setting up 2 wemos D1 mini in a mesh. The connection and sending works, but reading the message keeps crashing on sscanf() and I can't tell why
void incommingMessage( uint32 from, String msg )
    uint16_t tokenState ;
    uint16_t tokenID ;
    char char_array[32];
    Serial.printf("echoNode: Received from %u msg=%s\n", from, msg.c_str());
    strcpy(char_array, msg.c_str());
    Serial.println("string copied to char array") ;
    Serial.println(char_array) ;
    sscanf( msg.c_str(), "%d,%d", &tokenID, &tokenState ) ; // <-- catastrophic failure
    Serial.println("array scanned") ;
    token[ tokenID ] = tokenState ; // update token with state
    printNumber_("token ", tokenID ) ;  // macro to print txt and number
    printNumberln("= ",tokenState ) ;    // macro to print txt and number
AFAIK I am doing it right. I use 16 bit variables for %d. And I did not forgot the &. The message also has the correct format. In this case 50,50
The output upon receiving is:
echoNode: Received from 2485300209 msg=50,50
50,50
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Without sscanf(), the wemos does not crash.
Dit I do something wrong or am I looking at a bug?
Regards,
Bas
Quick glance. Shouldn't it be
    sscanf(char_array, "%d,%d", &tokenID, &tokenState ) ; // <-- catastrophic failure
I agree, but only because it would be clear to me. And I suggest doing it as a test anyway.
I don't use Strings, but shouldn't
   msg.c_str()
return a pointer to char?
a7
%d scans a 4 byte integer, you need bigger targets, or a different format.
I think %hd is used for 16 bit entities.
https://en.cppreference.com/w/cpp/io/c/fscanf
I have been unclear.
This..
and this
sscanf( char_array), "%d,%d", &tokenID, &tokenState ) ; // <-- catastrophic
I both tried. I started out with the char array as that is indeed the proper way like you point out. Later I changed it to msg.c_str() simply to see if it would make a change.
We got a winner though! (me because my wemos does not crash anymore).
Using uint32_t instead of uint16_t and using the char array seems to work. Apparently sscanf behaves differently with an 8 bit uController than on a Wemos. For an arduino Nano, I had to use 16 bit variables
The output:
echoNode: Received from 2485300209 msg=51,50
51,50
array scanned  <--  Got a winner!
token 51 = 50
Now I just need me to change the printing so that 51 and 50 become 3 and 2 respectively. That I can do.
Tnx for the assist!
Regards,
Bas
