ESP8266 keeps restarting & disconnected from wifi
I am doing home automation project using blynk app with three 230 V bulb and 1 AC fan , this worked really well, but I connected manual switch (for bulbs & fan) to ESP8266, after connected the switch the ESP8266 keeps restarting and disconnects from WiFi , do I need to give extra power supply to switch , if I have to give the power supply do I need to use relay or I can directly connect to 230 v supply
one has to be very careful connecting mains voltages to microcontrollers - usualy done thru opto-isolators
could you upload a schematic of your circuir and the code?
I have given a connection like this, I have given power to ESP8266 from USB cable, do i need to give ac supply for the switch through relay like i given to bulb
#include <BlynkSimpleEsp8266.h>
#include <ESP8266WiFi.h>
#define BLYNK_TEMPLATE_ID "TMPL3On5pdO-u"
#define BLYNK_TEMPLATE_NAME "HOME AUTOMATION"
#define BLYNK_AUTH_TOKEN "1QpA2HJ66oMMAnBSUaTpXLYraqTDIooP"
char ssid[] = "OPPO A77s";
char pass[] = "elai@2333";
bool fetch_blynk_state = true;
#define RelayPin1 5  //D1
#define RelayPin2 4  //D2
#define RelayPin3 14 //D5
#define RelayPin4 12 //D6
#define SwitchPin1 10  //SD3
#define SwitchPin2 0   //D3
#define SwitchPin3 13  //D7
#define SwitchPin4 3   //RX
#define wifiLed   16   //D0
#define VPIN_BUTTON_1    V1
#define VPIN_BUTTON_2    V2
#define VPIN_BUTTON_3    V3
#define VPIN_BUTTON_4    V4
bool toggleState_1 = LOW;
bool toggleState_2 = LOW;
bool toggleState_3 = LOW;
bool toggleState_4 = LOW;
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
int wifiFlag = 0;
char auth[] = BLYNK_AUTH_TOKEN;
BLYNK_WRITE(VPIN_BUTTON_1) {
  toggleState_1 = param.asInt();
  digitalWrite(RelayPin1, !toggleState_1);
BLYNK_WRITE(VPIN_BUTTON_2) {
  toggleState_2 = param.asInt();
  digitalWrite(RelayPin2, !toggleState_2);
BLYNK_WRITE(VPIN_BUTTON_3) {
  toggleState_3 = param.asInt();
  digitalWrite(RelayPin3, !toggleState_3);
BLYNK_WRITE(VPIN_BUTTON_4) {
  toggleState_4 = param.asInt();
  digitalWrite(RelayPin4, !toggleState_4);
BLYNK_WRITE(VPIN_BUTTON_C) {
  all_SwitchOff();
void all_SwitchOff() {
  toggleState_1 = 0;
  digitalWrite(RelayPin1, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
  delay(100);
  toggleState_2 = 0;
  digitalWrite(RelayPin2, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
  delay(100);
  toggleState_3 = 0;
  digitalWrite(RelayPin3, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
  delay(100);
  toggleState_4 = 0;
  digitalWrite(RelayPin4, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
  delay(100);
void manual_control() {
  if (digitalRead(SwitchPin1) == LOW && SwitchState_1 == LOW) {
    digitalWrite(RelayPin1, LOW);
    toggleState_1 = HIGH;
    SwitchState_1 = HIGH;
    Serial.println("Switch-1 on");
  if (digitalRead(SwitchPin1) == HIGH && SwitchState_1 == HIGH) {
    Serial.println("Switch-1 off");
  if (digitalRead(SwitchPin2) == LOW && SwitchState_2 == LOW) {
    digitalWrite(RelayPin2, LOW);
    toggleState_2 = HIGH;
    SwitchState_2 = HIGH;
    Serial.println("Switch-2 on");
  if (digitalRead(SwitchPin2) == HIGH && SwitchState_2 == HIGH) {
    Serial.println("Switch-2 off");
  if (digitalRead(SwitchPin3) == LOW && SwitchState_3 == LOW) {
    digitalWrite(RelayPin3, LOW);
    toggleState_3 = HIGH;
    SwitchState_3 = HIGH;
    Serial.println("Switch-3 on");
  if (digitalRead(SwitchPin3) == HIGH && SwitchState_3 == HIGH) {
    Serial.println("Switch-3 off");
  if (digitalRead(SwitchPin4) == LOW && SwitchState_4 == LOW) {
    digitalWrite(RelayPin4, LOW);
    toggleState_4 = HIGH;
    SwitchState_4 = HIGH;
    Serial.println("Switch-4 on");
  if (digitalRead(SwitchPin4) == HIGH && SwitchState_4 == HIGH) {
    Serial.println("Switch-4 off");
  Serial.begin(11520);
  WiFi.begin(ssid, pass);
  // Wait for connection
    Serial.print(".");
  Serial.print("\nConnected to ");
  Serial.println(ssid);
  Serial.print("IP address:100.67.247.217 ");
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(RelayPin3, OUTPUT);
  pinMode(RelayPin4, OUTPUT);
  pinMode(wifiLed, OUTPUT);
  pinMode(SwitchPin1, INPUT_PULLUP);
  pinMode(SwitchPin2, INPUT_PULLUP);
  pinMode(SwitchPin3, INPUT_PULLUP);
  pinMode(SwitchPin4, INPUT_PULLUP);
  //During Starting all Relays should TURN OFF
  digitalWrite(wifiLed, HIGH);
  //Blynk.begin(auth, ssid, pass);
  Blynk.config(auth);
  if (!fetch_blynk_state){
  manual_control();
  Blynk.run();
Your diagram indicates an external 5V supply.
No, switches that can switch 240V AC can also switch 3.3V DC. Switches connected like in your diagram require almost zero power.
You cannot use RX pin for a switch. Can you not use D4?
first, i have connected one switch to check that time also it worked well, after connecting 4 switches this problem arriving that's why I thought switch needs an external power supply
What's the trouble noted in the Crash Log ?
Connected to AMhd
IP address: 192.168.160.1
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00046670
~ld
� �n� r��n|�l�l b b r l�nb�n l � r l�l ��.......
Connected to AMhd
rll�r $ �n�l�b|�� �r b�b �nn lnn bb p�$b lrlp�n �l� bn�n�� b��nn'l� l � nnl nr���nbl� p�n r� b bn�n b��nn'l � nnl nr���nb � r��nb � � ��� l ��n� � �n� r��n|�l�l b b r l�nb�n l` � r l�l ��.............
Connected to AMhd
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
tail 0
chksum 0x2e
tail 0
chksum 0x2b
csum 0x2b
v00046670
~ld
� �n� r��n|�l�l b b r l�nb�n l � r l�l ��.............
Connected to AMhd
wdt reset
tail 0
chksum 0x2e
tail 0
chksum 0x2b
csum 0x2b
v00046670
~ld
Connected to AMhd
Showing like this
i have changed this line from my code , its working well now, thank you.
n #define SwitchPin1 10 //SD3
