I changed the ssid 、 pass、apikey, but because of security issues, I replaced it with xxxx
#include <WiFiClient.h>
#include "MAX30100_PulseOximeter.h"
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <ThingSpeak.h>
#define REPORTING_PERIOD_MS 1000
const char* apiKey = "xxxx"; // Enter your Write API key from ThingSpeak
const char* ssid = "xxxx"; // Enter your WiFi Network's SSID
const char* pass = "xxxx"; // Enter your WiFi Network's Password
const char* server = "api.thingspeak.com";
const char* resource = "/update?api_key=";
float BPM,SpO2;
WiFiClient client;
PulseOximeter pox;
uint32_t tsLastReport = 0;
void onBeatDetected()
Serial.println("Beat!");
Serial.print("Initializing pulse oximeter..");
Serial.print("Connecting to: ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi Connected.");
Serial.print("IP address: ");
// Initialize the PulseOximeter instance
// Failures are generally due to an improper I2C wiring, missing power supply
// or wrong target chip
if (!pox.begin()) {
Serial.println("FAILED");
for (;;);
Serial.println("SUCCESS");
// pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
pox.setOnBeatDetectedCallback(onBeatDetected);
pox.update();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
tsLastReport = millis();
BPM = pox.getHeartRate();
SpO2 = pox.getSpO2();
Serial.print("Heart rate:");
Serial.print(BPM);
Serial.print("bpm / SpO2:");
Serial.print(SpO2);
Serial.println("%");
// 使用 80 Port 連線
if (client.connect(server, 80)) {
Serial.println(F("connected"));
else {
Serial.println(F("connection failed"));
return;
Serial.print("Request resource: ");
Serial.println(resource);
client.print(String("GET ") + resource + apiKey + "&field1=" + float(BPM) + "&field2=" + float(SpO2) +
" HTTP/1.1\r\n" +
"Host: " + server + "\r\n" +
"Connection: close\r\n\r\n");
int timeout = 5 * 10; // 5 seconds
while (!!!client.available() && (timeout-- > 0)) {
delay(100);
if (!client.available()) {
Serial.println("No response, going back to sleep");
while (client.available()) {
Serial.write(client.read());
Serial.println("\nclosing connection");
client.stop();
// 每三分鐘會上傳一筆資料
delay(10000);
