ESP8266 - MQTT - Home-Assistant
Estimados,
Estoy intentando hacer funcionar una placa ESP8266, para encender un LED via protocolo MQTT. El mismo, sobre Mosquitto accionado desde Home-Assistant. He logrado, conectarla al MQTT server para publicar…Pero no logro hacer que el GPIO0 represente la orden.
Por un lado, les muestro el tablero.
De aqui, se controlara la luz…Les recomiendo que vean Home-Assistant para automatizar todo el hogar…Es muy interesante!
Los comandos, estan siendo activados…
Aqui el codigo del broker MQTT:
# Luz ESP8266 Nro. 1.
light:
  platform: mqtt
  state_topic: "office/light1/status"
  command_topic: "office/light1/switch"
  optimistic: false
Y por ultimo, el codigo de ESP8266
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// WiFi ssid and password
const char* WIFI_SSID = "internet_publico";
const char* WIFI_PASSWORD = "";
// MQTT server IP and port, username and password
const char* MQTT_CLIENT_ID = "office_light1";
const char* MQTT_SERVER_IP = "XXXXXXXXXXXX";
const uint16_t MQTT_SERVER_PORT = 1883;
// const char* MQTT_USER = "";
// const char* MQTT_PASSWORD = "";
// MQTT topics
const char* MQTT_LIGHT_STATE_TOPIC = "office/light1/status";
const char* MQTT_LIGHT_COMMAND_TOPIC = "office/light1/switch";
// Light
// The payload that represents enabled/disabled state, by default
const char* LIGHT_ON = "ON";
const char* LIGHT_OFF = "OFF";
boolean light_state = false;
int LED = 2;
WiFiClient wifiClient;
PubSubClient client(wifiClient);
void callback(char* topic, byte* payload, unsigned int length) {
  // handle message arrived
  if (String(MQTT_LIGHT_COMMAND_TOPIC).equals(topic)) {
    // test if the payload is equal to "ON" or "OFF"
    if ((char)payload[0] == (char)LIGHT_ON[0] && (char)payload[1] == (char)LIGHT_ON[1]) {
      if (light_state != true) {
        light_state = true;
        digitalWrite(LED, LOW);
        client.publish(MQTT_LIGHT_STATE_TOPIC, LIGHT_ON);
    } else if ((char)payload[0] == (char)LIGHT_OFF[0] && (char)payload[1] == (char)LIGHT_OFF[1] && (char)payload[2] == (char)LIGHT_OFF[2]) {
      if (light_state != false) {
        digitalWrite(LED, HIGH);
        client.publish(MQTT_LIGHT_STATE_TOPIC, LIGHT_OFF);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(MQTT_CLIENT_ID/*, MQTT_USER, MQTT_PASSWORD*/)) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      if (light_state) {
      // ... and resubscribe
      client.subscribe(MQTT_LIGHT_COMMAND_TOPIC);
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  // init the serial
  // init the build-in led
  pinMode(LED, OUTPUT);
  if (light_state)
  // init the WiFi connection
  Serial.print("Connecting to ");
  Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // init the MQTT connection
  client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  client.loop();
Desde ya muchas gracias! Ojala, podamos sacarlo…es muy interesante este software y la interaccion con Arduino, ESP y muchos artefactos de domotica!
No puedes poner una acción en el setup, allí definirás lo que después ejecutas.
en el
if (light_state)
Este programa solo te ejecuta en caso de que no a conectado con client
