ESP8266 MQTT lamps
Hey there !
I just spent a few days on this project from Instructables.
Everything is working great, but I can't achieve what I want to do with those lamps. The LEDs are actually always on, & switch on colors by touching the sensor; but what if I want the LEDs to be always off, & to switch on/change color ONLY when I touch the sensor ?
I'm actually a total begnner in this coding/soldering stuff, & trying to learn; but my brain can't succeed :-[
Here's the code used by the creator.
I tried to contact him via Instructables, but no answer, that's why I'm requesting some help here. I guess there's just some little things to tweak, but, no, I definitely can't find the issue by my own..
Thanks for your kind help, & sorry for my english. I swear I did my best :-[
But it's YOUR code that isn't working. Post that code.
My code is in attachment !
I didn’t change much, but MQTT’s topics names & LEDs swooshes speed :smiley:
Once again, both of the lamps are working with this code. I just want them to be turned off when the sensor is released.
synclamps.ino (10.8 KB)
Why did you not post code that will compile?
vi
  long startTime = millis();
    char payload[1];
There is just NO excuse for creating a one element array.
    itoa(hue, payload, 10);
You values in hue range from 0 to 360. That requires an array size of at least 4. You just sh*t on memory you don't own.
  if (sensorValue > SENSOR_THRESHOLD) {
If the value exceeds the threshold, do some stuff.
  // For determining first loop after touch is released
Then, check to see if the value is still above the threshold...
Since the value hasn't changed, the second test is going to evaluate EXACTLY the same as the first one.
So, where is the code to do that?
