I'm currently working on a project where I'm using an ESP8266 to connect to WiFi and MQTT to control a relay based on GPIO pin status and MQTT messages. However, I'm encountering an issue where sometimes, if there are WiFi connection problems or if WiFi is not available, the relay switching is not instant.
Here's a breakdown of the problem and the code I've tried:
I'm monitoring the input status of GPIO pin D6 via an interrupt. When there's a change in the pin status, I want to turn on or off the relay connected to pin D2 accordingly.
Below is the code I've tried, but it doesn't work
#include <ESP8266WiFi.h>
const char* ssid1 = "wifi1";
const char* password1 = "123456789";
const char* ssid2 = "WIFI2";
const char* password2 = "123456789";
const int interruptPin = D6;
const int ledPin = D2;
volatile bool interruptFlag = false;
void relayTask() {
pinMode(ledPin, OUTPUT);
for (;;) {
if (interruptFlag) {
if (digitalRead(interruptPin) == HIGH) {
Serial.println("Interrupt pin is HIGH");
digitalWrite(ledPin, HIGH);
Serial.println("Interrupt pin is LOW");
digitalWrite(ledPin, LOW);
delay(10); // Delay for 10 milliseconds
void input_ISR() {
interruptFlag = true;
void connectToWiFi() {
Serial.println("Connecting to WiFi...");
// Connect to first WiFi network
WiFi.begin(ssid1, password1);
unsigned long startTime = millis(); // Record start time
while (WiFi.status() != WL_CONNECTED && millis() - startTime < 10000) { // Try for 10 seconds
delay(1000); // Delay for 1 second
if (WiFi.status() == WL_CONNECTED) {
Serial.println("Connected to WiFi: " + String(ssid1));
return; // Exit the function if WiFi is connected successfully
Serial.println("Failed to connect to " + String(ssid1) + ", trying backup...");
// Connect to backup WiFi network
WiFi.begin(ssid2, password2);
startTime = millis(); // Reset start time
Serial.println("Connected to backup WiFi: " + String(ssid2));
Serial.println("Failed to connect to backup WiFi");
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), input_ISR, CHANGE);
// Start relay task
TaskHandle_t relayTaskHandle;
xTaskCreate(relayTask, "RelayTask", 2048, NULL, 1, &relayTaskHandle);
// Start WiFi connection task
TaskHandle_t wifiTaskHandle;
xTaskCreate(connectToWiFi, "WiFiTask", 2048, NULL, 1, &wifiTaskHandle);
// Nothing to do here
