I'm doing a project with a NodeMCU ESP8266 module where i just use it to turn an LED on or off from anywhere. I've simply used code from online and after some port forwarding it works! However, when i plug in the module, it works but after 10ish minutes, the device cannot connect to the server and i can't turn the LED on or off. I have to keep pressing the reset button on the ESP8266 to make it work.
#include <ESP8266WiFi.h>
const char* ssid = "*Not putting it in because of safety...*";
const char* password = "Not putting it in because of safety...";
const char* host = "192.168.0.25"; // (not actual one...)
//just write it here afterwards and upload
int ledPin = D3;
WiFiServer server(301); //just pick any port number you like
delay(10);
// prepare GPIO2
pinMode(ledPin, OUTPUT);
digitalWrite(D3, LOW);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
while (!client.available()) {
delay(1);
// Read the first line of the request
String req = client.readStringUntil('\r');
client.flush();
// Match the request
if (req.indexOf("") != -10) { //checks if you're on the main page
if (req.indexOf("/OFF") != -1) { //checks if you clicked OFF
digitalWrite(ledPin, LOW);
Serial.println("You clicked OFF");
if (req.indexOf("/ON") != -1) { //checks if you clicked ON
digitalWrite(ledPin, HIGH);
Serial.println("You clicked ON");
else {
Serial.println("invalid request");
client.stop();
return;
// Prepare the response
String s = "HTTP/1.1 200 OK\r\n";
s += "Content-Type: text/html\r\n\r\n";
s += "<!DOCTYPE HTML>\r\n<html>\r\n";
s += "
<input type=\"button\" name=\"bl\" value=\"Turn LED ON \" onclick=\"location.href='/ON'\">";
s += "
s += "
<input type=\"button\" name=\"bl\" value=\"Turn LED OFF\" onclick=\"location.href='/OFF'\">";
s += "</html>\n";
client.flush();
// Send the response to the client
client.print(s);
delay(1);
Any help would be appreciated!
Thanks!
